86 Carrera - Smoke from Wiper Stalk Housing. Any Ideas?
Electrical smoke from the housing into which the wipers, light, cruise control stalks insert.
Very real wisps of smoke that lasted no more than 5 seconds. All controls appear to function normally. Never happened before. Any Ideas? Thanks in advance ! |
Member 911 Anonymous
Do you have an after market Head Light Relay Kit? If not then your stalk has started to burn out. You need to take apart the stalk and check for shorts, this requires you disconnect the battery and remove the steering wheel.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
lol
In that case what do you think it is? |
ROW '78 911 Targa
Mine makes arcing noises
but works fine. I recon don't worry about it until it stops working.
Where did you get your kit?
ROW '78 911 Targa
Search for J-West relay kit as well. It will explain the relay kit others are referring to. Edit: never mind, it is your wiper switch that is smoking... No lighting circuits in it. Perhaps your wiper motor is overloading the contacts in the switch, causing the smoke, similar to what happens to the hi/lo switch in the turn signal switch... Sorry, should have read the first post better, most of the time it is the headlight switch in the turn signals smoking.. Last edited by timmy2; 08-24-2014 at 07:30 PM.. |
But the wiper lever is in the stalk too.
Did she smoke when your turned the headlights on and the wiper switch?
ROW '78 911 Targa
Ok, must be an '86 model thing, my wiper controls are on the right hand side of the wheel on a different stalk. My GM has wipers and cruise on the turn signal stalk... ![]() Now if the OP knew that the wiring for the different stalks runs through the clamshell housing that covers the column, and if that is where the smoke is coming from, he might be interested in reading about all the devices that could possibly cause the smoke. Sent from my iPhone using Tapatalk
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 08-25-2014 at 12:09 AM.. |
Thanks for all the input…..
So I had some time to spend with car….
I turned on the headlights and at first the headlights did not come on.
When they did they were stuck on high. No flash available. |
ROW '78 911 Targa
Ok, now we are getting somewhere. Definitely sounds like the headlight contacts in the turn signal stalk are a distinct possibility.
My suggestion would be to inspect them and either repair or replace the unit and install the J-West or similar relays to protect the circuit from future damage. There are a lot of threads with great instructions here at Pelican. The advanced title search is your friend.
