samourai71's Avatar
battery for a 911 coupe 3.2 1985
I'd like to replace my old mammoth battery with a new smaller sized.
What are the stats I should look at.
I don't do race and I don't use the car during winter.
Thank you in advance.
Old 01-03-2013, 09:42 AM
gtc gtc is offline
abides.
gtc's Avatar
Pretty much anything will be smaller and lighter than the stock battery, so it sort of depends how much starting capacity you want, how much weight you want to save, and how much you want to spend.
Graham
1984 Carrera Targa
Old 01-03-2013, 10:22 AM
wwest's Avatar
Costco...
Old 01-03-2013, 10:41 AM
lpsalsaman's Avatar
Just like GTC said, it depends how big and how much starting power you want. I still have what I call "2 1/2 ton truck" battery on mine, but next time I will go smaller. If you notice there are 3 holes where your battery holder screw can be placed, you can see it when you remove the battery. So the next time I will go with the second one which will be a medium to small size, in order to retain cranking power but you could go smaller. I would look for a battery that can give you the same cranking power you have in the bigger one or at least close enough to it but yet a in a smaller size. Just my 2 cents...
U.S. Army Retired
85 Targa Guards Red
2018 BMW 530i M-Sport
Personal Quote: "Do whatever makes you feel good"
Old 01-03-2013, 11:15 AM
samourai71's Avatar
I'm looking more for a smaller size than weight.
I'd like to spend $200-250
and as for starting power, how do you measure the power you need?
I'm looking at optima red?
and I realize I'll need to custom mount the new battery.
Old 01-03-2013, 11:41 AM
Barrpete's Avatar
I installed an Optima red top 34R with the cutting board mounting solution
Mounting an Optima battery
The 34R has the reversed terminals so it fits with the existing cables.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 01-03-2013, 12:32 PM
nineball's Avatar
another battery install thread
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-03-2013, 01:15 PM
I used the template posted by Barrpete above. Purchased the 1/2" black cutting board from Target and mounted my Red top optima in my 87' 911 last year. Looks great and fit perfect.
Brad
Old 01-03-2013, 02:10 PM
76 911S Targa
I had the Optima Red in my 1985. Worked well and cannot spill or overflow, a big plus. Same battery they use on the F16.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 01-03-2013, 02:28 PM
Shhhh... Uhhh
Creve's Avatar
Here's what I did
Put in an Optima yellow top. Got the mounting plate that fit the optima off of eBay. It was a perfect fit!
"Dyin' ain't much of a livin' boy."
- Outlaw Josey Wales
Old 01-03-2013, 02:36 PM
86 ssinit's Avatar
Follow nineballs thread
Lightweight and half the size. You can find the battery on eBay for about $140
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 01-03-2013, 02:51 PM
Rescuer of old cars
Arne2's Avatar
I've got an Odyssey 925 in my car, with a Rennline mount kit. Was in the car when I bought it, but seems to be a decent lightweight alternative. The Odyssey is about 25 lbs.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-03-2013, 03:36 PM
samourai71's Avatar
Yes, I was looking for that option but I can't seem to find a oddysey dealer in Montreal.
Sent from my iPad using Tapatalk HD
911 black coupe 1985 3.2
Old 01-03-2013, 03:42 PM
samourai71's Avatar
How about kinetics?
There's a dealer near my house.
Which model should I look at?
Thank guys for all the info, always mighty appreciated.
Old 01-03-2013, 04:36 PM
nineball's Avatar
i run them in all my cars and never had a problem (that wasn't my fault). $118 shipped.
Kinetik HC800 (KHC800) 950 Amp 36 AH 12V Car Battery Power Cell
Old 01-03-2013, 04:40 PM
samourai71's Avatar
How about those rennline mounts, are they adjustable?
Has anyone installed one with a different battery than the odyssey 925?
Old 01-03-2013, 05:10 PM
kuba_kuba's Avatar
Another vote for Optima Red Top with cutting board mount. It was my first mod!
'88 911 Targa
Old 01-03-2013, 06:29 PM
Thanks Guys, I found you here. My 1986 has been sitting for too long. Battery DEAD. I went to my mechanic and he pulled out a new Interstate off the self. I told him you guys said a smaller battery would be fine. After looking in his book again, he gave me a shorter battery... also an Interstate.
After removing the old, the new one slipped right in. I will need to secure it, but I will be bringing in the car for some service.
With a cloud of blue smoke, the car started right up... It's been sitting for about 3 years.
I plan to get her registered for the summer!
____________________
1986 Red Carrera Coupe
Old 05-29-2014, 05:23 PM
testa-rossa's Avatar
I went with the Rennline Odyssey mounting kit and an Odyssey battery. Done.
Old 05-29-2014, 07:23 PM
