Brew Master
cabmandone's Avatar
My window regulator spring retainer, slow power window fix.
I was reading a post the other day about a small clip that falls out of the window regulator that holds the helper spring tension. After reading about it, I went out to my car, rolled up my window and... click.. the piece broke off of my regulator. I removed the regulator and put in a bolt with the head ground down for some clearance, put two nuts on the bolt and put the spring on the proper side of the bolt for tension. I also sprayed the hinge point with Boeshield since there is no room or way to put grease in that point. Now the window goes up and down like it should. I decided to check my passenger side window and wouldn't you know it, the retainer was broken on that one too. Fixed them both. The person who posted their fix used a stainless steel button head bolt but I didn't have enough clearance for that so I ground the head of a bolt.
Link to the other fix: Slow window fix
Another thanks to Pelican for this great forum with great users willing to post their experiences with the cars we all love.
Old 04-22-2014, 11:50 AM
Kraftwerk's Avatar
Nice fix, that bolt, and great pictures.
Today the passenger door was apart for the second time this week.. Window was non- op a few months back. Yesterday I got it working. Then it didn't, so I drove 2.5 hrs with the window down..Had to get home! Today (third time) I went inside the door, checking for frayed wires etc, noticed one of the wires to the motor was disconnected! No way.. That was an easy / lucky find.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 04-22-2014, 05:05 PM
Brew Master
cabmandone's Avatar
Nothing makes you happier than a no cost fix
Old 04-22-2014, 05:57 PM
Recently dealt with "slow window" and found that the 911 turbo (930) at least for 1979 has a different setup.
There is a flange that is part fo the frame that the spring is attached to......no way for it to break.
So if you have a 79 930 and a slow window look for other reasons.
In my case it was a screw that was too tight and seized. It was part of the arm mechanism of the regulator.
Easy fix. But to find that out I had to take the whole thing apart. Not so easy.
Old 06-03-2014, 07:09 PM
bugstrider's Avatar
Great post!! Will dig into our slow mover as soon as I get some spare time or find a way to create 36 hours into a 24 hour day...
Subscribed
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 06-03-2014, 10:53 PM
