dzlndan's Avatar
Bizarre twin plug set up ??
Purchased an 1982 targa without any background info. Can anyone help me identify this bizarre twin plug set up? It has twin MSD. Car runs good now but the (rear?) Distributor will need a new belt soon and I have no clue where to ascertain one of those puppies.
Old 06-01-2014, 06:51 AM
Banned
Could it just be a single plug with an extra msd in case of failure? I only see one coil. And that black thing in the first picture only has 4 terminals, not 6.
Does it actually have 12 plugs?
Old 06-01-2014, 07:23 AM
I would rather be driving
jpnovak's Avatar
There was a thread years ago about cam driven twin plug setups. Search for Grady Clay's response on the subject.
In a way its a "hidden" twin plug setup.
Old 06-01-2014, 07:25 AM
dzlndan's Avatar
No twin set up, 12 plugs second cool is hidden to the left of engine mounted near the fuse panel, just the way the photo is it looks like possible 4 but it def has six plug wires on the back dist cap. I will try to get better photos and maybe even from under side to see the belt drive off the cam.
Old 06-01-2014, 07:33 AM
dzlndan's Avatar
This pic shows the second coil
Old 06-01-2014, 03:47 PM
Wow, cool setup!
2001 Boxster S
1984 Carrera
1976 912e
1993 968
1986 944 Turbo
Old 06-01-2014, 06:21 PM
pors1968's Avatar
It set like old airplane engine .Double ingition .
Old 06-02-2014, 03:15 AM
bavaria911's Avatar
I don't see it. Where is the 2nd coil?
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 06-02-2014, 04:14 AM
Elombard's Avatar
Its up on the side on the right - black, kinda stealthy.
I have heard of these set ups but I cant remember where I read about them. I wonder if the belt that drives the 2nd dizzy will even be available? Maybe its just an MFI belt?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-02-2014, 04:17 AM
resident samsquamch
sand_man's Avatar
Posting this for a visual. A 962 engine (not mine) with that setup. It uses the "regular" dizzy in the typical spot to fire six plugs and then an additional dizzy off of one of the cams to fire the other six.
-jeff
Old 06-02-2014, 06:22 AM
dzlndan's Avatar
Some more photos
From the under side
From the top side in the back
Old 06-02-2014, 05:31 PM
dzlndan's Avatar
Two more from the top side
Old 06-02-2014, 05:34 PM
Max Sluiter
Flieger's Avatar
MFI belts are wider than that. You might be able to find something from Gates on McMaster-Carr or SDP/SI that would fit as a replacement. Have fun changing it though.
Old 06-02-2014, 06:06 PM
Elombard's Avatar
Yeah it looks like they clearanced the shock mount cross bar with a BFH. Looks like something I would do. I think I can see some numbers on the belt i n one of the pics, maybe if you can get it off you could source it. I would be scared to lose the timing if I took it off with the motor installed.
Old 06-02-2014, 07:06 PM
Less brakes, more gas!
euro911sc's Avatar
You could remove the cap on the rear dist. and observe the orientation of the rotor when you set the engine to TDC. Then mark it. When you put the belt back you should be able to hit that mark. Should be obvious if you are +-1 tooth on the belt.
My concern would be the changes in timing over time as the belt wears and stretches out. How do you tension it? what tension do you set it at if its adjustable?
Note there is no belt on the 962...
Interesting setup...
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-03-2014, 10:17 AM
jpnovak's Avatar
I have tried and tried to find the previous post on the subject. I can't seem to find it but I know its there.
Old 06-03-2014, 10:23 AM
resident samsquamch
sand_man's Avatar
Not to hijack in any way as I realize the OP's second dizzy is being driven by a belt via cam, but I thought I would share these pics. Several years ago, Neil Harvey of Performance Developments (a premier 956 and 962 engine builder) was handling all of the machine work on my 930 engine. I decided to go twin plug. This was one of the options he mentioned. Obviously borrowed from his years with the 962 engine:
-jeff
Old 06-03-2014, 10:55 AM
resident samsquamch
sand_man's Avatar
^^^this dizzy would have been attached to the turbo oil scavenge pump, which runs off of the driver's side cam.
-jeff
Old 06-03-2014, 10:57 AM
safe's Avatar
Really cool!
Magnus
Old 06-03-2014, 01:53 PM
dzlndan's Avatar
Yes exactly where my belt is connected
Old 06-03-2014, 04:37 PM
