With the compressor off the car, it takes between 10 minutes to 60 minutes to take one apart. It all depends upon whether you have all your tools lined up and how many of these procedures you have under your belt. PP has a link to a summarized tear down
Here.
From our experience of tearing down over 500 Denso 10P15 series compressors over the past 15+ years, when we have a unit past the 80K miles marker we see wear issues with pistons and bores, over 100k miles its wobble plate and piston half bearings.
It is not economical to jig bore or jig grind a set of cylinders (they are aluminum bores and do not have steel liners) and match up new pistons (which don't have rings). When wobble plates wear you toss them away with the shaft since they are a fixed unit.
So before you buy a seal kit you inspect the unit first before putting out the money.
If things look questionable or not economical then buy a new Denso, and move on to the next project.
