rw7810's Avatar
Another Turn Signal Issue
What causes both the inside direction signals to flash at the same time while the exterior signals are operating just fine ??
Robert Williams
70' 911T
Old 06-02-2014, 09:33 AM
Send a message via Skype™ to Porboynz
Incorrect or ill matched bulbs in the 4 corners will do this as will bulbs that are lower wattage than spec. I ditched my Narva bulbs for Hella bulbs and the double flashing inside went away. Funny thing was the first flash was always good, the correct warning bulb in the instrument panel flashed nice and bright, then both bulbs would flash together but less brightly.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 06-02-2014, 11:51 PM
Worn out indicator relay could cause the same symptoms. Try to fit a new one, and see if all lights up as it should.
Thomas
1973 911S Targa 2.4
Old 06-03-2014, 01:04 AM
