How do I disable that annoying buzzer on start-up?
My '78 911 has a small symbol for seatbelt and brake on the dash
which lights up and sounds a VERY irritating buzzer
when the ignition key is engaged,
even when the belts are fastened.
Solutions appreciated.
Old 11-10-2014, 11:11 AM
pop out the gas gauge, reach in and pull it out. should be easy to locate, with all the noise it makes. if the gas gauge hole is too small for your hand, the next hole over will work too.
206 637 4071
Old 11-10-2014, 11:14 AM
Thank you! I want to do the same to my 79 SC. I hate that damn buzzer.
1999 996 C2 sold - bought back - sold for more
1997 Boxster BSR POC/PCA #254
1978 911 SC Daily Driver
Licensed DE/TT Instructor
Old 11-10-2014, 03:28 PM
porwolf's Avatar
This is the first thing I pulled out when I got my '79SC:
I remember that I was able to pull it without removing any gauges. I think I just reached under the dash and felt where the sound and vibrations came from.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 11-10-2014, 03:56 PM
Rescuer of old cars
Arne2's Avatar
Oh no, you can't pull the buzzer! It's an original part, your car will be worth much less w/o it!!
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 11-10-2014, 04:16 PM
MattKellett's Avatar
I was able to reach my relay through the front trunk.
Matt Kellett
87 Carrera Coupe - Marine Blue
60 MGA - Chariot Red
66 Jaguar MKII - Sherwood Green
09 VW GTI - Candy White
Old 11-10-2014, 08:36 PM
Enginerd
TxGerman's Avatar
Adding to this old thread....I have an '82 SC, just replaced my ignition switch (40 y.o. switch failed).
I found an easier way to disable the key switch buzzer, just remove the black connector next to the ignition switch/lock assembly.
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 12-17-2022, 11:09 AM
The buzzer was above the glovebox
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-17-2022, 11:44 AM
Registered Minimalist
75 911s's Avatar
On my 75 if you remove that relay the car wont even start.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-17-2022, 07:31 PM
