RDM RDM is offline
Coram Deo
RDM's Avatar
Odometer fails after "electrical event;" speedo soldiers on
All,
As I was accelerating onto the highway last Monday, my car experienced some sort of electrical event. The car became unwilling to rev. The dash lights (fused, thanks, Pelican!) went out. The clock stopped working. The odometer stopped working. All the gauges still worked, though.
I don't know what happened to cause the event, but noodling with the oxygen sensor relay resolved the revving problem. A new fuse resolved the lighting and clock problem.
But the odometer is still dead. That it went out at the same time as all the rest points toward an electrical problem. Is there a way for these to fail electrically rather than the typical failed nylon gear?
Anyone have a line on a speedo shop in Germany should it come to that?
Thanks.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 06-03-2014, 10:32 AM
Electric surge? How's the voltage regulator?
Old 06-03-2014, 11:21 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
The voltage regulator is one of the solid state external ones, new about 18 months ago.
Dru
Old 06-03-2014, 01:25 PM
db_cooper's Avatar
Maybe the ground strap between the battery and the chassis is due for a change..or the ground strap between the transmission and the chassis under the car. That would explain your electrical brown out. Or..could be your ignition switch..
The Odometer is driven by the motor that drives the speedo...that is likely coincidental to your brown out, you have a bad gear in the Odometer..it just happens
Old 06-03-2014, 05:11 PM
Yup..bad gear
1986 3.2 Carrera
Old 06-03-2014, 06:25 PM
db_cooper's Avatar
Try the Porsche Owners Club Germany...if Google translate is working..reach out and see who may be nearby that can make the repair..the odometer is a very common problem
Porsche Owners Club Germany - DER Club fΓΌr Fahrer und Freunde des luftgekΓΌhlten Porsche 911
Old 06-03-2014, 07:13 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Both ground straps are new in the last 3 months.
My ignorance is showing- how does the ignition switch cause electrical spikes?
Dru
Old 06-04-2014, 01:51 AM
