SC Engine drop
It seems I have an engine drop ahead of me as the clutch on my 81 SC seems kaput.
I have some research & searching to do on the site to gain from others experience before I undertake this project.
If you know of some good threads that go through the steps of an engine/trans drop that can help me plan this out, please post em on this thread.
Thanks...
Old 06-03-2014, 07:13 PM
From the tech article section.
Engine drop
Chris
'75 911s Targa
Old 06-03-2014, 07:41 PM
Name your location.......
This is my suggestion to you how to get this job done efficiently and safely. There are countless people who have done this procedure successfully in many different methods and techniques. So find out who you want to be your mentor or adviser from this post. I am sure there would be many that would volunteer for this job. There is a post in the engine rebuilding about 'first engine drop' and thread went up several pages with too many good and questionable suggestions.
Choose a couple of guys who you feel comfortable communicating and discussing about the project. Ideally, it would be nice to have someone present during your first engine drop. Either your mentor or a friend. If you need an engine yoke, I could lend one to you. It (yoke) just came back from Germany. Keep us posted.
Tony
Old 06-03-2014, 07:52 PM
I just completed my first porsche engine drop on my 1977 2.7 CIS. Took me about 8 hours with many breaks to double check the tech articles. The most time consuming and nervous part for me was jacking the car up to and down from the 24" height at the torsion tube covers. I used two floor jacks and wood to lower the engine and transmission with the help of my father. I removed the rear valence to gain some clearance.
I expect reinstalling the motor to take less than 4 hours.
Btw, I'm 29, but have been working on European cars since my early teens.
Old 06-03-2014, 08:46 PM
2 hours is what it takes me. Where are you?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-03-2014, 09:43 PM
I have reviewed many threads and found lots of great advice. This forum is great.
What I find us that the hard and costly part is after you have it out! :-)
Old 06-06-2014, 05:28 PM
Alan L's Avatar
First sort out how you are going to raise the car far enough and support the engine/trans as you drop it. Without the 'proper' (ie first time - nothing fabricated) gear, this will be about the most time consuming. From memory I need about 30" clear of the bottom of the rear bumper. Or you can gain a bit more by removing the bumper. Depends what turns out easiest. The height you need will depend on how you finally support the engine/trans to get it out. The job is fairly straight forward. Don't be scared of it. 2nd/3rd time around is a piece of cake :-)
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-06-2014, 05:36 PM
fred cook's Avatar
Email
I just sent you an email w/instructions for removing and replacing an SC engine. When I did the job the first time, I wanted a check list to make sure that I wasn't forgetting anything.
Fred C.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-06-2014, 08:29 PM
