Using three 48mm IDA carbs?
Might be a dumb question, but while I was thinking about carbs today I started thinking of using three 48mm IDA's. IDA carbs are $500 each and a manifold could be fabbed up cheap.
Just an idea...
Old 06-05-2014, 12:55 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Where do you place them so that the big hump of the fan still fits?
If you place them further to the firewall....the depth of the 3 carbs will add up to more room than you have.
Bob
Bob Hutson
Old 06-05-2014, 01:28 PM
Vintage Owner
Jack Stands's Avatar
The length of the intake runners becomes a problem as well. The 914s that we're converted to the single carb setup with the long intake runners never ran very well. OK of a VW Beetle, but not much else.
If you're going to use long intake runners, how about a Holly or Quadrajet, should fit better behind the cooling shroud.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-05-2014, 02:33 PM
Under the radar
Trackrash's Avatar
$500 a carb for 48 IDAs? Sounds real cheap. Does that include air cleaners, linkage, fuel lines, and I guess you don't need manifolds.
All said and done you would be money ahead with PMOs.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-05-2014, 07:55 PM
BTDT, and it doesn't work. Air mixed with fuel really doesn't like to turn corners and one would have to design, test and build a VERY complex intake manifold to prevent fuel from dropping out and puddling.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-05-2014, 08:29 PM
I didn't think it was a good idea, but rather just wondering if anyone tried it... I'm still on the fence of ITB's and a standalone or just making it easy with some 46mm PMO's and a 12 plug...
Old 06-05-2014, 08:41 PM
As Steve said, plus the intake runners will ice up on a cool evening, making the problem even worse for the fuel trying to move into the heads inside.
We had a carter afb four barrel on a corvair, with this type of set up. uh... nope
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 06-05-2014, 10:21 PM
HawgRyder's Avatar
I did an install of 2 SU carbs on a V8 once.
It worked really nice...the SU's have no accel pumps...so the piston in them varies the throat size to prevent "bog".
For a 383 it got very good mileage.
Perhaps something like that would work if the carbs wereplaced on short log manifolds with the carbs facing outwards?
Bob
Bob Hutson
Old 06-05-2014, 10:51 PM
otto_kretschmer's Avatar
if you do this, you may consider plumbing oil that's going to the oil tank through the manifold and use it to heat the manifold
this would make the manifold more challenging to build but that's part of the fun
Old 06-15-2014, 09:58 PM
