Both turn signals on constantly when lights are on
Obviously not the way it is supposed to work, but since it wasn't always like that and I haven't moved any wiring connections so I am wondering if this is actually in the turn signal/high and low beam switches on the steering wheel. I seem to remember seeing something about this on the forum some time ago. Any tips to pass along?
Thanks.
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 06-08-2014, 11:14 AM
RETIRED
Joe Bob's Avatar
Swap relays?
2012 ML350 3.0 Turbo Diesel
Old 06-08-2014, 12:47 PM
Check the bulbs.
Old 06-08-2014, 01:37 PM
Joe - swap relays as in change the wiring routing or replace the actual relays?
Chirp - may be being dense here but how would the bulbs account for that.
Thanks for the responses.
911 w/ 3.2
Old 06-08-2014, 06:15 PM
RETIRED
Joe Bob's Avatar
Turn signal/flasher relay. Do the hazard flashers work?
Old 06-08-2014, 06:19 PM
Send a message via Skype™ to Porboynz
Its always the earth, most of the time.....
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 06-08-2014, 09:29 PM
Brew Master
cabmandone's Avatar
Sounds to me like you've got a ground problem. I'd check the grounds on your intake, the heavy ground under the car and the ground lug for the battery in the trunk area. It could be a bulb too. I had a bulb blow on my trailer one time that threw my entire brake system out of whack. I can't explain how but somehow it grounded caused all sorts of problems.
Old 06-09-2014, 03:54 AM
Hazard flashers do work properly in isolation (meaning if you turn them on with nothing else on they work properly).
With the above test confirming they work OK, wouldn't that rule out a ground issue?
Thanks guys.
911 w/ 3.2
Old 06-09-2014, 06:48 AM
