Both turn signals on constantly when lights are on
Obviously not the way it is supposed to work, but since it wasn't always like that and I haven't moved any wiring connections so I am wondering if this is actually in the turn signal/high and low beam switches on the steering wheel. I seem to remember seeing something about this on the forum some time ago. Any tips to pass along?
Thanks.
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
RETIRED
Swap relays?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Check the bulbs.
Joe - swap relays as in change the wiring routing or replace the actual relays?
Chirp - may be being dense here but how would the bulbs account for that. Thanks for the responses.
RETIRED
Turn signal/flasher relay. Do the hazard flashers work?
Its always the earth, most of the time.....
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
Brew Master
Sounds to me like you've got a ground problem. I'd check the grounds on your intake, the heavy ground under the car and the ground lug for the battery in the trunk area. It could be a bulb too. I had a bulb blow on my trailer one time that threw my entire brake system out of whack. I can't explain how but somehow it grounded caused all sorts of problems.
Hazard flashers do work properly in isolation (meaning if you turn them on with nothing else on they work properly).
With the above test confirming they work OK, wouldn't that rule out a ground issue? Thanks guys.
