Post Sealants for rebuild
Are the sealants used for aircooled aircraft engine assembly ok to use for rebuilds?
Old 09-13-2001, 06:48 PM
Senior Member
Doug Zielke's Avatar
Post
Can you (brand) name them for us?
I can't see why they would not work in a 911 motor. Who knows...they might even be (dare I say it) cheaper!
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
"If it ain't broke...we'll help you fix it 'til it is!"
Old 09-13-2001, 07:11 PM
Early_S_Man's Avatar
When I first notified this board (about 8 months ago) that Loctite 518 was the replacement for the discontinued Loctite 574 product ... the data came from an FAA-approved list of compounds for use on piston-driven aircraft engines!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
Old 09-13-2001, 07:20 PM
Irrationally exuberant
ChrisBennet's Avatar
Post
518 works great for cam towers but I wouldn't use it for sealing the case without specific information that it is safe for that application. Just my $.02 -Chris
Old 09-14-2001, 04:03 AM
Post
Cheaper? Naw if you think Porsche parts are expensive try looking at light aircraft parts. Every piece that is critical to the operation of the engine has to be certified and tested, hence an alternator which is basically a Ford part can cost $1000.00, dual iginition is an absolute requirement, not for performance but for redundancy, and that means DUAL ingnition, two of everything.
Remember, if it fails on your Porsche you can still walk home.
Robert
Old 09-14-2001, 07:48 AM
