Trouble threading spark plug
well I pulled all my rockers and pulled the 1-2-3 side cam...so I take out the spark plugs...
3 and 2 come out okay...but #1 I had trouble with as I was taking it out...on the same part of every rotation it got stiff...so I turn...hit a spot that was rough and 360 degrees later I hit that rough patch... So I assume it was cross threaded the last time someone put in a plug...so I gingerly took it out and when I tried putting the new one in...same deal...I've used my hand and have been very careful to get the threads started right...I don't want to do anymore damage to the heads... what do I do now??? should I just thread it on as carefully as possible or am I FUBARed... MJ also by shining a light into the hole I noticed alot of black crud on the piston top...I will post pis later...is this oil getting into the CC? also plug 2 and 1 had black crud on the electrode too... any ideas??? time of ra rebuild? |
PRO Motorsports
I've got a spark plug thread chaser that you can borrow. Come by the shop and get it.
As for the crud on the plugs and piston tops, sounds like rebuild time if it is oily. If it is just sooty, then it's just a mixture or spark issue. But, most likely it's worn valve guides, worn piston rings, or bad valve stem seals.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 Last edited by Tyson Schmidt; 09-22-2002 at 01:10 PM.. |
great....
I am coming by the shop on monday or tuesday to drop off a smashed oil line...I'll grab the tool from you then... I'll bring the plugs in too...I must admit the valves and plugs have not been done in about 20K...I found a bad wire...and the mixture has been off for a while...I am putting all new wires...964 cams...new rotor/dizzy cap...the works... The plugs look sooty...like a grimey crud...not too wet... Once I get it all together I'll bring it by so you guys can get the mixture right so I can pass the smog test...and maybe we can figure out what it really is...the motor runs really strong and I hope I am tackling most of the loil eaks I've been havng this time around too...we'll see thanks MJ Last edited by 82SC; 09-22-2002 at 01:15 PM.. |
PRO Motorsports
That is encouraging. If it is sooty, and you found a bad plug wire or two, then the engine is probably fine and simply needs a tuneup.
Hope that relieves some stress. See you Monday!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Author of "101 Projects"
Sounds like there is crap (oops, not allowed to use that word), err junk in there like dirt or carbon. What was on the plug? Any chaffing of the threads? Despite common wisdom from Porsche, I would use some anti-seize in this case, and thread/remove the plug to see if you can clean it out in there...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
