Driver's License Owner
CIS Piston "Swirl"
I have read where the "swirl" on CIS pistons creates the needed turbulence to better atomize fuel since the CIS system lacks in that regard. Makes sense. So when I move to a JE piston, is has protrusions, but not the same swirl. Any "on the ground" info out there as to whether JE or other aftermarket pistons work well with CIS? I was leaning towards keeping my CIS, but this is a factor in that decision.
Thanks -- Chuck 1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700 |
The JE s work well in the CIS
Bruce |
It's not for "swirl". The dome is placed in order to push the compressed mixture towards the spark plug. It is meant to provide a cleaner burn and requires less ignition timing.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Fleabit peanut monkey
The Watson needs to figure out if a distributor re-curve is in order and bank on using higher octane gas. Do all the pre-SC CIS cars run "regular" octane gas?
1981 911SC Targa |
I think they do. Compression was lower and the combustion chambers are 25% smaller.
