Folks,
Recently bought and installed the Innovate LM-2 to help me tune my 3.2L engine that is equipped with a XDi single plug ignition. Out of the box the LM-2 seems to be reading solid AFR however I can't seem to get a good RPM reading. The XDi controller has a tachometer signal output (brown wire) that is connected to my vehicle's tach (black/purple wire). The vehicle tach works just fine. I bought the LM-2 analog cable and connected the tach input wire (black/white) to the XDi tach signal output (brown). Meanwhile I'm getting RPM readings on the LM-2 that remain constant as I rev the engine (like 1360 RPM) or jump to #'s that don't reflect the actual RPM (3650 RPM although I never rev'd it that high). I called Innovate and they suggested I try adjusting some of the LM-2 RPM setting configurations - no joy. - I tried trailing edge, jumping between each cylindar config/pulses and - Tried the same for leading edge. - Also tried grounding the Analog cable blue wire. No impact, no idea - anyone care to make suggestions (short of buying a different sideband :roll eyes .Thanks, Gordo
Don "Gordo" Gordon '83 911SC Targa |
connect it to the #3 plug wire at the plug. this helps to keep it away from the other wires.
it does not matter which plug it connects to, just keep the wire and connector for the LM away from other plug wires.
Analog RPM or Inductive
T77 - are you referring to the inductive RPM adapter that Innovate sells? I have the analog - which is just a wire harness and plug connector.
Thanks, Gordo
Try disconnecting the car tach and only connect the LM2 tach. Does it work like that?
Will Try
Haven't tried that one yet Dr J - but willing to give it a go. Thanks, Gordo
inductive.
try what drj said. try the settings again too. i am thinking i had to set mine to something wierd to make it work. been quite a while.
Gordo, let me know how the LM2 works out. I need/want to get a wideband and I'm looking at either the LM2 or the Zeitronix. I've got MSD 6AL boxes that I should be able to grab the tach signal from (1 is running the tach, think I can use the other box to feed the wideband). Most interested in logging, not so much real time viewing.
Todd
'81 SC |
Daytona Sensors LLC - WEGO IV Wide-Band Air/Fuel Ratio Tuning Aid
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Did you ground the tach adapter? You need both tach and signal.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Straight shooter
I have used the LM-2 with RPM input just fine both with and without the plug wire clamp. Have you been through the configuration steps yet?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Innovate LM-2 RPM Input
Folks,
Sorry for the delay - got sidetracked for a bit addressing a few other items. I tried all possible configuration settings on the LM-2 with no joy. Additionally tried grounding the blue wire with same results - crap signal ![]() Meanwhile -Dr J's Suggestion Was Spot On... Thanks! Tonight I went ahead and cut the tach lead off, leaving the LM-2 analog RPM wire connected to the XDI RPM output. This plus grounding the blue wire and configuring for leading edge and I have good RPM readings (finally). It allowed me to make a few recorded runs and replays this evening - giving me a solid feel for my AFR's through the RPM range. All good - but now what? I would like to be able to run the LM-2 and still be able to use my tach - any ideas what I can do to provide both LM-2 and tach a RPM signal concurrently? ![]() Thanks for the input folks. For Todd - hard for me to make a call on the LM-2 just yet. Based on the difficulties I've had with getting it configured to read RPM's I would tend to give it a thumbs down, however I have no experience with other wideband systems - which may have their own or similar initial configuration issues...
1984 Porsche Carrera
Have a look at a thread by scarceller on what he did with his 84 carrera when he was logging rpm but using a tec edge product he made a little unit that plugged into the rpm and that converted the signal properly this may be your issue?
Awesome. Glad my suggestion worked. I asked you to just connect the LM 2 and disconnect the car tach as a test. I have an hpx from electromotive and the tach signal out was a 5V square wave. Ultimately I built a small adapter box with an NPN transistor to boost the tach signal closer to 12 volts for the Porsche tach. It has been working for years. Are you comfortable soldering electronics? The circuit is pretty simple. I will draw up a crude schematic and post later. If not let me know and I will wire one up for you.
Good - But Why
I'm comfortable with soldering, and would appreciate a rough schematic. Not sure I understand the problem or solution though - are you tapping a different source for the Porsche tach input and leaving the Innovate LM-2 connected to the HPX RPM output as a separate circuit? Gordo
beancounter
I've got electomotive XDi2 ignition on my 930. I spliced directly off the tach signal wire to feed an innovate DL-32 data logger. Works perfectly on the dash tacho and the data logs I record for real-time or later viewing in logworks software. No "secret handshake" required that I recall in my case, was pretty much plug-n-play. Seems strange that yours would be different. There are some set up parameters that might need adjusting on the LM-2 for the rpm channel, have you checked those? No direct experience with the LM-2, but I have a bunch of innovate stuff, and while you can adjust many of the input parameters directly on their hardware, I think its much easier to adjust those settings using the software interface in logworks. Requires getting your laptop to "talk" with the innovate hardware, which generally means you need a USB--->serial adapter since you can't buy a PC with serial ports anymore.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Gordo, in my case, I used two transistors because the 5 v square wave tach out form the HPX would sometimes cause my tach signal to intermittently go flat as though it reached a maximum. I documented that here: LM2-tach signal goes flat
In that case I boosted my signal to 12 V then took part of that signal for the LM-2 and part as the input to a second transistor to buffer the signal. In your case, it seems that your LM-2 works fine, which may be due to improvements they did in software. So, the circuit I recommend for you is this one: ![]() The "tach signal in"- is what comes out of the electromotive unit. The transistor dissipates enough current that it won't need a heat sink. If you use a different NPN transistor, you may need to use a heat sink. My notes show that my tach would draw 1 amp of current. Let us know how it works out!
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! Last edited by Dr J; 07-23-2014 at 04:38 PM.. |
Not to hijack the thread (as everyone says), but...
I just bought a LC-2 to monitor my AFR because my engine was running lean (15:1) after rebuild--reference my "Crappy Dyno Run" thread on the rebuild forum... I'm installing it on a Carrera engine with Motronic and headers with O2 sensor. I would like to keep using the Motronic closed loop O2 circuit. Can I use the supplied LC-2 wideband O2 sensor for both the Motronic ECU and the AFR gauge... Or will I need a second bung? Thanks, Tim
84 911 Targa 3.4L |
OK, I just read the LC-2 manual... and yes there is an output for the ECU which mimics the stock narrowband O2 sensor.
84 911 Targa 3.4L |
Dumb question
Why does Innovate stuff seem to be so difficult to get working? Seems to be a lot of posts.
Voltage From Tach
Here's another oddity (or at least I thought so).
As I was checking for voltage on various wires left over from the old engine harness (I made my own engine harness), I'm fairly certain that the black/purple wire (coming from the Porsche tach) showed something like 4.5v (with the key on). Seemed a bit odd, but I didn't give it much thought. Wonder if this has anything to do with my LM-2 not reading RPM when connected to the tach. Gordo
