-   -   Custom order rear deck lid badge? (http://forums.pelicanparts.com/porsche-911-technical-forum/818619-custom-order-rear-deck-lid-badge.html)
Arne2 08-08-2014 11:11 AM
More editing, hope this helps. Lots of possibilities from just that first decent 3.2 image.
http://forums.pelicanparts.com/uploa...1407524988.jpg
http://forums.pelicanparts.com/uploa...1407525009.jpg
http://forums.pelicanparts.com/uploa...1407525022.jpg
http://forums.pelicanparts.com/uploa...1407525034.jpg
Ferrariguyma 08-19-2014 05:50 PM
Summary...
Is anyone still making 3.2 grill badges? I ordered one from pelican a while back only to get my money refunde when they told me their supplier was not making the badges an longer.
dan88911 08-19-2014 06:56 PM
Dimensions
Originally Posted by Arne2 (Post 8198542)
Here are the "correct" (?) dimensions.
Width = 84.45mm
http://forums.pelicanparts.com/uploa...1407209230.jpg
Height = 21.40mm
http://forums.pelicanparts.com/uploa...1407209266.jpg
If not using tape mount, the mounting studs need to be about ¾" in length. Height turns out to be exactly the span of two bars on the later plastic decklid grill.
http://forums.pelicanparts.com/uploa...1407209388.jpg
http://forums.pelicanparts.com/uploa...1407209435.jpg
Hey Arne,
Are you working on producing any badges? If not.
Any chance you can share the dimensions on the numbers.
dan88911 08-20-2014 01:06 PM
bump
Arne2 08-20-2014 08:45 PM
Dan, I have no plans to build these, since I have no access to a CNC milling machine, nor to a 3D printer. Mine is one of the ones Pelican used to sell, purchased from a Pelican who bought it a few years back. Either CNC or 3D printer would be a piece of cake to use to make these, depending on the material you prefer. For aluminum, the CNC mill is the ticket.
Here's some additional measurements. Take them with a small grain of salt, due to the cheap Chinese HF micrometer.
Badge height - 21.40mm
Width - 84.45mm
Numeral height - 21.40mm, same as the badge
Numeral width - 35.75mm
Space between numerals - 12.95mm
Period size - 6.10mm, centered between numerals
Period lower edge - 1.50mm above bottom edge
Badge thickness including numerals - 6.30mm
Badge base thickness - 3.10mm
Numerals stand 3.20mm tall on badge
On the back side, mine has two small bosses with threaded holes for mounting hardware. The bosses are narrow enough to fit between the grill bars.
Mine has a small, 45° chamfer around the edges of the numerals and period, as seen here:
http://forums.pelicanparts.com/uploa...1408596166.jpg
dan88911 08-21-2014 12:00 PM
Thanks, Arne.
Arne2 08-22-2014 07:53 PM
Quick comment - I do not have badges for sale. I photoshopped those images just in hopes of giving examples that people could share with custom badge makers. Sorry for any confusion.
Rebadge.com 08-24-2014 05:14 PM
Ferrariguyma, I am making these badges. They are of 304 stainless steel, hand polished, with an aluminum backer plate powder coated gloss black. We offer different finishes of course, so you may choose what you like. Please email me at kyle@rebadge.com and we will get you whatever you'd like!
dan88911 08-25-2014 04:27 PM
How about posting some photos, Rebadge
JQ911 08-25-2014 06:27 PM
3.2 badge
I have a 3.2 badge which I have not installed yet since I am waiting for my tail to be painted. Since Rebadge is based in NJ, I can bring it to him so he can get an exact measurement, if he wants to. Let me know if I can further help.
http://forums.pelicanparts.com/uploa...1409019736.jpg
Draden 08-25-2014 07:00 PM
Have my 2.8 on order with Kyle at rebadge. Woohoo
Rebadge.com 09-09-2014 05:25 PM
Hi guys! Things are moving along, thank you all for the support! I've been making the emblems at 3.25" x .875" as per the recent requests. The most common, but not limited to, finishing has been a gloss black backer plate with polished engine designations. You are not limited to this, though; we offer several powder coat colors as well as some unique stainless finishes. I will be posting some pictures soon of the pieces we've made recently, before we ship them out.
JQ911: I would love to get together to pull some more measurements for verification, as well as some R&D on the spacing of the mesh grilles [we'll be designing and offering bolts and nuts for mounting our badges in the weeks to come]. Please email me so we can schedule a meet up and pin point the specifics that are necessary. Thank you very much! kyle@rebadge.com
Rebadge.com 09-15-2014 05:53 PM
Hi guys. Here's a quick shot of a 3.5 we did for Otto. The designation isn't touched; he requested bare metal so he can color match other trim.
I will have more pictures up soon. Thanks!
http://i36.photobucket.com/albums/e3...psamescrkl.jpg
Arne2 09-15-2014 07:27 PM
Not bad. Compared to my 3.2 emblem from the former supplier, I think the verticals need to be a bit thicker, as indicated by the red lines. The verticals should be the same width as the curl on the lower bit of the '5' or the upper and lower of the '3'.
Just my opinion. Once on the car, that's going to look pretty good as it is there.
http://forums.pelicanparts.com/uploa...1410838043.jpg
Rebadge.com 09-17-2014 04:16 AM
Thanks Arne, I'll update it immediately and get all the dimensions locked down soon. Once I have all the proper dimensions for each number, it becomes a very easy drop and replace system, design-wise.
OttoB 10-13-2014 10:13 AM
I am very pleased with the results - Kyle, great job, man!
http://forums.pelicanparts.com/uploa...1413223976.jpg
kuehl 10-13-2014 12:28 PM
Nice work Kyle!
JQ911 10-13-2014 01:54 PM
I finally had time to mount mine yesterday. Met Kyle a few weeks ago and he got some measurements on this badge. Hopefully, I'll get an extra one if its already available.
http://tapatalk.imageshack.com/v2/14...84d329bb04.jpg
piscean911/914 11-18-2014 05:05 PM
email sent - brad in seattle!
Rebadge.com 11-26-2014 03:34 AM
Good day gentlemen!
I want to thank you all for your support, we've received a lot of orders lately, exclusively through this thread. I know Draden has been waiting patiently through the redesigning process, and the long lead time at the machine shop, so we will be expediting the finishing and shipping as quick as possible. As I receive and finish the badges, I will be posting pictures to showcase the font for all of the different designations, as well as our designs for the old RS and Carrera badges; a special RST piece is in the works as well. This includes, but is not limited to: 2.1, 2.8, 3.0, 3.2 and 3.5. Stay tuned for more pictures, as well as a stud and nut application to replace the 3m tape, for a mechanical, and adjustable, fastening system. Thank you all again! Have a fat and happy Thanksgiving!
lin7310948 11-26-2014 03:47 AM
very pleased with mine!!!http://forums.pelicanparts.com/uploa...1417006000.jpg
Draden 01-14-2015 11:40 PM
Wait til you see the final product. It's been 4 months working out the details to get it perfected. You guys won't have to wait like that. I just really was interested in giving him time to develop it and wow was it worth it. the badges are so perfect the font, size quality etc and trust me when I say his work is better than any previous photo seen on this site. Again I hope he posts the picture of the one he is sending me. It looks awesome.
Mr.Alex 01-16-2015 03:26 PM
Any news on the updated design with the rear mounting studs?
Draden 01-18-2015 02:01 PM
2,8 Decklid Badge
Today, I received my 2.8 badge from Kyle
He did such beautiful work, Thanks Kyle, I could not be happier about the size, shape, quality, fonts, polish it's very high quality and a work of art!
http://forums.pelicanparts.com/uploa...1421622020.jpg
Arne2 01-18-2015 02:09 PM
I agree, Draden, that one looks "right". If I didn't already have my 3.2 emblem from the prior supplier, I would buy one like that in a heartbeat.
Rebadge.com 01-19-2015 08:27 AM
Hi guys. Thank you for the kind words Draden! I'm very happy you love it!
Yes, the new design is ready to go; I will be getting pricing on incorporating the rear studs within the next week or two. As soon as I have that info I will let you all know.
Cheers!
Kyle
Uwon 01-23-2015 07:15 PM
Just got my badges from Kyle at Rebadge and had to lay them on the deck lid.
Great quality and interpretation of my back of the envelope design.
Kyle was easy to work with-many thanks.
Johan
http://forums.pelicanparts.com/uploa...1422072776.jpg
RSBob 01-25-2015 06:37 AM
Originally Posted by lin7310948 (Post 8371316)
I bet women swoon when they see your very large number. ;)
Car Couture 02-06-2015 01:16 AM
Hi Guys!
Here's a sneak preview of some of my badges, these are just prototypes and will be fully chromed when ready. No further information :rolleyes:
http://forums.pelicanparts.com/uploa...1423217654.jpg
clex2 02-06-2015 07:31 PM
↑ looking forward to the final product :)
Rebadge.com 02-10-2015 01:27 PM
What material are you making them out of, Car Couture
Car Couture 02-12-2015 01:12 PM
lightweight ABS plastic, UV resistant chrome/gold coated (not on the picture)
Badges are coming up for sale soon :cool:
911 R, ST - Dashboard and Decklid
2.0, 2.2, 2.4, 2.5, 2.7, 2.8, 3.0, 3.2, 3.6, 3.8 or on request. Chrome/Black detailed
Rebadge.com 02-24-2015 02:59 AM
Hi guys. I'm finalizing fabrication and pricing on embedded stud mounts, but I could use a little help.
Would someone please be able to provide spacing/ layout location of the OE studs? I want to make sure that our spacing is perfectly matched for the grilles, and there are no issues when mounting them where they belong. Any help is much appreciated!
anglophone1 02-25-2015 08:31 AM
Rebadge- sent you a PM.
Rebadge.com 03-05-2015 01:43 PM
Anglophone you have been contacted, thank you!
I'm still looking for stud spacing on the back of the badges. I should have pricing and lead time next week, and I'd like to know exactly how to set them up. Thank you to anyone who can help!
Car Couture 03-16-2015 03:30 PM
First prototype, 3.2 is up next!
https://fbcdn-sphotos-c-a.akamaihd.n...eaf6865b7f58b8
piscean911/914 03-16-2015 03:52 PM
hi - i don't think that the stock 911 badges had pins - i think they were pressed together from both sides - the replacement badges had pins and the 914 badges had pins - i will look at what i have and provide more info - hope this helps - looking forwards to my 2.1 badge!!! brad in seattle
Rebadge.com 04-06-2015 04:52 PM
Hi guys. I have the green light from a second shop to incorporate mounting studs.
I need to know grille slat spacing so I know how to machine the studs and imbed them properly. If anyone is available to measure and provide this information it will be a huge help!
Thank you in advance for your time, gentlemen!
Kyle@rebadge.com
9736342664
Arne2 04-06-2015 07:07 PM
Plastic engine grill as used from mid-70s through '89 measures 11.96mm slat spacing on my cheap HF digital micrometer. That would be a really snug fit, so I'd go a touch smaller than that, maybe 11.5mm.
techweenie 04-06-2015 07:19 PM
Any plans for a 3.4 badge?
