Certified User
billjam's Avatar
89-94 rear window seal OK in 88 car with 88 glass?
Will the standard '88 rear window fit OK with the later (89-94) one-piece rubber seal?
There's plenty of discussion here regarding the fitting of later front windscreens and seals into pre 89 cars, but I can't find anything related to the rear window.
I am about to do a total repaint and retrim of the car and I already have the later front rubber and glass organised. It would make sense to change the rear seal to the later type as well, but I don't really want to use a 964 rear window if I can avoid it.
If the 964 glass is slightly smaller, a spacer in the window groove (like a wire) might help it fit better.
Anyone been there?
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 01-30-2013, 09:13 PM
Certified User
billjam's Avatar
No takers?
Bill
2024 Macan S
Old 01-31-2013, 08:48 PM
Certified User
billjam's Avatar
One last try. Surely someone has done this for the rear window as well as the front!
Bill
2024 Macan S
Old 02-02-2013, 04:20 AM
Almost Banned Once
sc_rufctr's Avatar
I'm interested as well. I'd really like to ditch the alloy trim on the rear seal.
I've replaced the rear side window seals on my SC with 993 seals.
Worked out great. The 993 seals are (were) cheaper than the pre 89 seals.
I used stock SC side glass, not 993 glass.
- Peter
Old 02-02-2013, 04:37 AM
Bill, there is a thread out there somewhere. I think if I recall for the rear window the glass needs to match the seal. 993 glass and seal works, according to what I recall, as well as 964 glass and seal. Let me see if I can find and post the link for you.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 02-02-2013, 05:08 AM
Windshield gasket, replace '86 with 964 style?
There are a few more threads out there, but only a few seem to consolidate all the feedback.
How's the turbo running?
Emery
Old 02-02-2013, 05:13 AM
Can I eliminate the black aluminum window trim?
Emery
Old 02-02-2013, 05:23 AM
Certified User
billjam's Avatar
Thanks for those links Emery. They didn't turn up in my search - getting the search text right is a bit of a black art sometimes.
It seems like most who have played with the rear window have used 964 glass as well as the seal.
However I did find one thread where someone used early rear glass with a 964 seal. They used some wire as a spacer in the glass groove of the seal to make up for the smaller early glass.
I'd love someone to confirm that this will work.
930 is running well, but unfortunately no longer in my stable. I'm currently getting ready to repaint my 88 Carrera and drop in a 3.6.
Bill
2024 Macan S
Old 02-02-2013, 05:57 AM
Certified User
billjam's Avatar
Some good links there Bob, thanks.
I agree, it seems that the consensus is to use matching seal and glass.
However, there were a few references to using early rear glass with 964 seal if a spacer of some sort is used to make up for the smaller size of the early glass.
A couple of posts mentioned that the 964 glass was about 5mm larger on all sides.
Does anyone have a rear 964 seal lying around that they could measure?
I'd like to know the depth of the glass groove.
I figure if it is something like 15mm and I put a 5mm spacer in the bottom of the groove, the remaining 10mm should be enough to secure the glass.
While we are at it, can anyone confirm the thickness of rear window glass?
Bill
2024 Macan S
Old 02-03-2013, 05:19 AM
proffighter's Avatar
Interested how this went out...
Roland
930 Turbo '81 Too many modifications to list
Old 07-16-2014, 04:49 PM
Certified User
billjam's Avatar
Me too!
Now that I have finally got my engine running, my thoughts are turning to repainting, so this subject is becoming relevant again.
I already have a 964 rear seal - just need to know how to make it work with an '88 rear window.
Bill
2024 Macan S
Old 07-17-2014, 05:07 AM
