Jon's 3.2 Hot Rod build
Hi Folks , I've been lurking on here for a little while and thought id start a build thread on my car .
I own a small VW restoration company in Wiltshire - England and was recently offered a 3.2 at a price I could not turn down . Always had a hankering for an early 911 or 356 but prices are prohibitive so I decided to build my own . So this is what I picked up - 1986 - 3.2 - Euro spec car, RHD ![]() Non Runner as purchased - back to my place on a trailer ![]() Up on a ramp to see haw rotten it is ![]() I was expecting the worse and I got what I was expecting ;-) Inner wings ( Fenders ) on front ![]() Rust under the front ![]() The normal sills - Kidneys etc ![]() Jacking points ![]() Some rust in the rear 1/4 ![]() First Job was to get it running - after a bit of research and testing I changed the crank speed sensor and it burt into life - Not Flames but it did look like it - I Guess there was a fair bit of oil that had managed to get past the valves etc into the exhaust - after a while it cleared
Love the smoker shot!
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Going by the pics i have seen of the various classic VW models you have restored, I'm sure you'll do a great job on your 3.2 also. Good luck and keep posting pics and details of the process.
Cheers from NZ, Frans |
Wow - non sunroof euro motor car - that is a great starting point. Do they salt the roads over there? I know it rains a good bit but I am always surprised how even more modern cars rust so much. I grew up in Seattle - similar weather but galvanized cars dont rust out.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
As I have the car running I'm happy that the engine is OK - I do have a quite loud knocking on the right hand side that could be the rockers - or maybe the cam chain - I will investigate this later .
I have been looking at all the body and bumpers etc and have realised that if I am going to get this to a high quality car I will have to replace all the rubbers and trim anyway - so I decided to build myself a little Hot Rod . The main thing I wanted to do was to build it all from steel , using as many original parts as possible . Some of which have come from this very forum - so thanks for that . The first bits to be found were the rear bumpers - From a SWB car as I like the trim more . ![]() I removed the trim which was in very good condition ![]() Lots of black rubbish ![]() After a bit of cleaning it comes up ok - needs a bit of straightening and blasting on the inside ![]() Not much in the way of progress but its something |
