-   -   so this is how a backdate project starts... (http://forums.pelicanparts.com/porsche-911-technical-forum/819396-so-how-backdate-project-starts.html)
SpyderMike 10-23-2018 10:34 AM
I agree! The seats fit me perfect and I like them. I am looking at options and the houndstooth centers are sweet.
SpyderMike 11-25-2018 09:56 AM
Found a fellow Pelican offering up a painted grill...thought I would give it a try. I like it!
Before:
http://forums.pelicanparts.com/uploa...1543168484.jpg
During:
After:
7783911 03-11-2019 05:57 AM
looking great Spyder!
Flojo 03-11-2019 07:10 AM
The plastic grilles "work" a lot when they get hot, meaning they expand... if paint is not primed correctly (heat conform plastic coating prior paint) it will brittle.
SpyderMike 03-24-2019 01:51 PM
Time will tell!
Well I took it upon myself to change out all of the engine fuel lines, and I am really glad I did. The return line was found to have some cracks in it. I also installed a new fuel filter.
It was a bit of a challenge doing this job with the engine in the car. You have to work while looking through mirrors. My earlier removal of some of the systems ( ruise control, engine blower) and then further taking more bits out during this process, made it possible. I used the lines now being provided by Paul Mason and they were of great quality and he was a pleasure to do business with. I was an early adopter of his product and he continually improved them. He sent me updated hoses during my installation.
I also replaced the airbox as I found it cracked in a few places from age. I am going to experiment with using the new base while cutting the old top to allow for a better sound in the cockpit at higher revs.
Mason_paul 03-31-2019 07:04 AM
Thanks for the kind words Mike! I’m looking forward to seeing that you got back on the road soon!
SpyderMike 03-31-2019 10:49 AM
A few pictures from the latest work. The new return section, the new fuel filter and fuse line, and new/revised filter box. I also took the opportunity to really clean my AFM and intake elbow. The car runs great.
http://forums.pelicanparts.com/uploa...1554054428.jpg
Now I am hearing the front wheel bearings moan when at a crawl. That is next.
I am also working on a fresh air blower system....made out of easy to source bits.
SpyderMike 06-05-2019 04:40 PM
Finally got around to replacing the inside rear view mirror. Check out how badly the old one was after 34 years in California. It just started disintegrating.
http://forums.pelicanparts.com/uploa...1559778014.jpg
That was a quick 5 minute fix.
SpyderMike 06-05-2019 04:47 PM
This project took a little bit longer. Since I pulled the A/C systems, and with the black interior, I wanted a fresh air blower system to give me some sense of airflow. I came up this this until I decide if I want A/C or not. I took an inline DC blower used for boat bilge venting, attached it to a hole to the outside (where the front A/C Condenser fan hole was), ran some smooth wall ducting and adapted it to the dash vent. Then I installed a PWM DC controller so I could adjust the volume of air. I had to de-solder the control potentiometer from the circuit board of the controller and extend it into the cockpit. Time will tell if it is enough airflow. The whole design was a little over $100 and most of that was the ducting I chose.
http://forums.pelicanparts.com/uploa...1559778322.jpg
SpyderMike 06-05-2019 04:56 PM
Here is the small on/off/potentiometer controller knob in the center:
http://forums.pelicanparts.com/uploa...1559778904.jpg
I got power from my switched bus. I measured 2 amps at 13.5VDC for full flow. I used a 5 amp fuse.
SpyderMike 10-07-2021 08:23 AM
Okay, the car has pretty much been running fine, until recently. I troubleshot it and found the reference sensor was open circuit. I ordered the BMW equivalent for that and the speed sensor (P/N 0261210002) for some $57 each. Within and hour they were in...easy fix for me. The car started right up and idled/ran the best it has in years. I highly recommend this change out for any car of this age that hasn't had it done yet. I followed these guidelines:
http://forums.pelicanparts.com/porsche-911-technical-forum/552276-no-spark-problem-finally-resolved.html
The hardest part of this event for me was removing the rubber grommet that passes through the firewall!
SpyderMike 03-02-2022 11:57 AM
I haven't been driving the car much lately as the starter was becoming a bit of a pain. When heated up, it wouldn't turn the engine over. Finally I decided to tackle this with a new geared starter...IMI 101N. The old one had served me well and will be kept.
Put the car on jackstands and bear hug the transmission with extensions and a swivel to get the hex bolts out. I had to lengthen one ground wire for hot start relay and reroute a couple of other wires as the connections are in another location. There is slight rubbing on the heater hose, but it fit pretty nice. It is a different sound when starting for sure...after 32+ years of driving this car...but it works!
http://forums.pelicanparts.com/uploa...1646250736.jpg
http://forums.pelicanparts.com/uploa...1646250960.jpg
SpyderMike 08-24-2022 01:08 PM
Everyone kept noticing the screws I had hiding the side panel holes, so I decided to do something about it. I bought Porsche trim pieces, drilled holes in them where the screws were and screwed them on. The biggest hassle to this whole task was the installation of the rubber seals on the backside of the trim pieces...ugh.
http://forums.pelicanparts.com/uploa...1661371631.jpg
On to the next task at hand...the lop sided stance. I am a half inch different side to side in height.
Jonny042 08-24-2022 01:26 PM
Nice!
hughc 08-24-2022 03:04 PM
sub
SpyderMike 09-28-2022 12:09 PM
Another update...the low cost battery I was using was just not up to the task...so I bought a Lifpo one based on my research here. It is smaller in height and a little bit thicker in depth. They give you foam shims and those worked perfect. I needed longer bolts and happen to have some handy. Super light weight with many more cranking amps. Happy!
So I have used a Oddessey 680 (that is what the battery holder is sized for), the inexpensive Universal shown below in comparison and now this battery.
http://forums.pelicanparts.com/uploa...1664392086.jpg
SpyderMike 08-31-2023 07:29 PM
LOL, I thought I was done...nope. I realized that I wasn't driving the car much during the hot weather which is getting hotter longer. So air-conditioning is now the main focus. I am going with a hybrid system consisting of Classic Retrofit and Griffiths parts. Here is my AC thread:
https://forums.pelicanparts.com/porsche-911-technical-forum/1144750-1985-ac-project.html
Matt at Pelican Parts 09-01-2023 09:00 AM
Awesome thread Mike! It looks like you've put in a lot of hard work over the years!
SpyderMike 09-01-2023 06:46 PM
Thanks Matt! There is always something to fiddle with on this beast! I just can't leave it alone!
tagamaynila 11-14-2023 02:58 PM
How is your car? Just saw your thread yesterday while I was looking for backdating info. I must say this is very informative not only on your detailed description of how you did it yourself but also the cost and parts information. Well done!
SpyderMike 11-14-2023 07:22 PM
Thanks Tagamaynila! The car is great. Of course, I started another project on it. I am putting in electric AC using a hybrid of stock, Griffiths and Classic Retrofit parts. You can find that project here:
http://forums.pelicanparts.com/porsche-911-technical-forum/1144750-1985-ac-project.html
I took a couple of months off to travel and have fun, but I will be back to it soon.
Thanks for checking in. If you have any questions...feel free to reach out.
tagamaynila 11-15-2023 10:46 AM
SpyderMike, good to know you car car is doing great. By the way it looks awesome. The other thing I like is that you post a new thread when you do other things. This way it is keeps things organized. Very much like everybody who has a Gbody our AC needs to be updated. For sure I will be following this new AC thread, fascinated and learning along the way.
SpyderMike 11-15-2023 05:07 PM
Thanks again! I really like this site for all the information that is available. I just try to pay back by posting things I think might help, even if it a mistake I have made, and to do it in a way that might be easy to find.
I hope my hybrid AC works, but, if it doesn't, I will keep at it until it does!
SpyderMike 05-12-2024 10:08 AM
So far, the new hybrid AC system works! I am now in the "dial it in phase"...and waiting for warmer weather.
SpyderMike 05-27-2024 04:47 PM
Due to the new AC system equipment location, I needed to come up with a windshield washer system. I finished it today and here it is:
https://forums.pelicanparts.com/porsche-911-technical-forum/1162210-my-1985-windshield-washer-hack.html#post12256552
Total cost around $25.
SpyderMike 06-22-2025 05:15 PM
And the process keeps moving along. The AC system still works great with no issues. For a while I have heard the groan in the front while coming to a stop or a slow turn. I am pretty sure I know what it is. I think the last front bearing change was in the early 1990s somewhere between 100k and 150k miles.
Anywho I got the new parts in from Pelican and started the process of taking everything apart. What a mess! The races are a bigger and I will be using my grill to heat things up as I only got one out with a hammer/drift method. I have got to clean the part too.
So far, things look good for 250,000 miles and 40 years!http://forums.pelicanparts.com/uploa...1750637701.jpg
http://forums.pelicanparts.com/uploa...1750637725.jpg
SpyderMike 09-13-2025 04:42 PM
Today was door day. I haven't had door stops/stays for years while I looked for something cool. I finally got tired of not finding anything and decided to just install some OEM ones. I did do the modification of trimming back the black rubbers. I also used bolts at the body flanges. Both doors have a nice feel to them without pops.
http://forums.pelicanparts.com/uploa...1757806920.jpg
http://forums.pelicanparts.com/uploa...1757806941.jpg
SpyderMike 09-13-2025 04:46 PM
Did I mention it was door day? I also rebuilt the strikers while I was at it. Nothing fancy, just new plastic inserts.
http://forums.pelicanparts.com/uploa...1757807109.jpg
Now I see that my driver's door needs adjustment as the top is a hair out further from the bottom. That might be why I always need to close it twice with the second being a slam.
That goes on the TO DO list as next in line.
TastyReuben 09-13-2025 06:01 PM
^ this has been on my to do list for a while. What bit is used to remove the striker plates though?
SpyderMike 09-13-2025 06:18 PM
I used an M8 12 point metric:
http://forums.pelicanparts.com/uploa...1757812701.jpg
SpyderMike 09-13-2025 07:05 PM
Here is the video I watched to understand how to do it:
https://www.youtube.com/watch?v=KVInAg3_KIA
SpyderMike 09-27-2025 06:22 PM
Well, my newish fuel sender seemed to be failing. I spent some time troubleshooting it and figured it out.
The cause of failure was that the float does not float. It moves fine once out of the tank, is it is not getting stuck in the tube. The float must be absorbing fuel as it rests wherever it is when placed into the tank. This was verified by removing the outer tube and observing it not rise when placed into the 3/4 full talk.
Luckily I kept the original which was failing due to the tube being a bit out of shape...the float physically jamming in the tube. I swapped the original tube for the new one and it seems to be indicating properly.
Time will tell. I notified the seller. It was a JP Group Dansk sender PN 90174180100-MFG350.
