Shift Knob Pattern Question
I noticed on some knob inserts there is a triangle on the pattern. Sometimes it is on the line leading to the R, other times it is between each vertical grouping. What does this triangle mean?
See here for an example: http://www.pelicanparts.com/catalog/images/Connect-Images/91142407101-M826.jpg This one has two: http://c767170.r70.cf2.rackcdn.com/B90142401300.jpg
Andrew 1987 Carrera Cabriolet 1988 Carrera Coupe (RIP) Gone are the days we stopped to decide where we should go......we just ride. |
Rescuer of old cars
Indicates that there is a spring preload you have to push past to get into that gate.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Thanks!
Thread Tools | |
Rate This Thread | |
