Dear Friends
I have the 1976 911 and I would like to know the part number for this plastic cap for the body I´m no longer using the side rockers so, I would like to close the hole with a set of new plugs Thanks
Where are you located? Sometimes you can find the right size plug at your local hardware/home improvement center.
Chris '75 911s Targa |
I´m in Brazil
A plug for this hole is relatively simple, the problem is this one has a low profile, is white or transparent and most of the plugs I found in a hardware store was black and very thick That´s why I´m looking for the correct Part Number Thanks |
Not 100% sure, but I think 411-837-111
Todd
1989 911 Targa |
Is it # 999-703-033-40? 25mm, our host has them, along with other sources.
Or 411.837.111 (as tholyoak found when I was searching) Note that I have seen the same plug used in multiple locations, so you may want to get some extra.
Who, What, When, Where, Why and How. Last edited by 93nav; 04-27-2017 at 03:48 PM.. |
411-837-111 is correct.
81SC Coupe Tony Kart/Yamaha |
I'll give 411 -837-111 a try
Thank you All!!! |
I have about 5 used ones
Lorne M.
83 SC |
Hello
I need 3 of those, do you mind in PM a picture of them? Thanks |
I will post a picture of them tomorrow.
Lorne M.
83 SC |
these are what I had extra.
Lorne M. ![]()
83 SC |
