Question I need help to locate this Part number
Dear Friends
I have the 1976 911 and I would like to know the part number for this plastic cap for the body
I´m no longer using the side rockers so, I would like to close the hole with a set of new plugs
Old 04-27-2017, 12:01 PM
Where are you located? Sometimes you can find the right size plug at your local hardware/home improvement center.
Chris
'75 911s Targa
Old 04-27-2017, 12:37 PM
I´m in Brazil
A plug for this hole is relatively simple, the problem is this one has a low profile, is white or transparent and most of the plugs I found in a hardware store was black and very thick
That´s why I´m looking for the correct Part Number
Old 04-27-2017, 12:40 PM
tholyoak's Avatar
Not 100% sure, but I think 411-837-111
Todd
1989 911 Targa
Old 04-27-2017, 03:36 PM
Is it # 999-703-033-40? 25mm, our host has them, along with other sources.
Or 411.837.111 (as tholyoak found when I was searching)
Note that I have seen the same plug used in multiple locations, so you may want to get some extra.
Who, What, When, Where, Why and How.
Old 04-27-2017, 03:44 PM
81SC's Avatar
Todd
411-837-111 is correct.
81SC Coupe
Tony Kart/Yamaha
Old 04-27-2017, 05:57 PM
I'll give 411 -837-111 a try
Thank you All!!!
Old 04-29-2017, 07:33 AM
I have about 5 used ones
Lorne M.
83 SC
Old 05-09-2017, 04:26 PM
Hello
I need 3 of those, do you mind in PM a picture of them?
Old 05-09-2017, 04:38 PM
I will post a picture of them tomorrow.
Lorne M.
83 SC
Old 05-09-2017, 05:31 PM
these are what I had extra.
Lorne M.
83 SC
Old 05-10-2017, 03:12 PM
