A/C deletion: what is that?
Hi,
I deleted my A/C system almost 2 years ago, thinking I cleared everything. A question remains regarding a post on used parts . Here is the picture and circled the part. Can somebody tell me what it is??? ![]() |
El Duderino
Evaporator
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Lash
That looks like the evaporator, that is the fin/coil that gets cold and the fan blows air across it.
The other larger fin/coil is the condenser that normally is installed on the rear decklid grill. You should find the part you circled inside a plastic housing which is usually next to the blower fan. |
Agreed on evaporator. Usually resides in "smugglers box."
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Evaporator....
2001 Boxster S 1984 Carrera 1976 912e 1993 968 1986 944 Turbo |
OK,
which means that this big rectangular block fits into that: ![]() Thanks all. That was not entirely clear to me! |
I was asking, because when I bought the car, there was no rear condenser, no compressor, and no evaporator/blower… I saw some blower but never this exact piece.
Yes Mat. As I recall, the open smugglers box you show... that space goes all the way to the floor board. There's an air cavity at the bottom, the evaporator above that, then the fan on top which we see the casing for in your photo.
French Import
Email sent.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Thread Tools | |
Rate This Thread | |
