Autocross/Hillclimbs
Unusual engine code
So here's my current mystery. I bought a 77 targa converted to slant nose yesterday, and I can't seem to figure out what engine I have. Should have been a 2.7 according to vin 9117210595
However the numbers by the fan are *3280888* and 930/06
930/06 indicates 3 liter
*3280888* I find one reference to, here: Porsche Engine Numbers
But that points to a really early motor and doesn't match the 930/06
Here are pictures
2x 1984 944 N/A; 1988 951S Silver Rose; 81 VW Rabbit Diesel; MK4 VW R32
President - Bridge City Autosports
http://www.bcautosports.club
Old 07-25-2014, 09:58 AM
Is it 930/06 or 930/08?
In the /08-case: 3.0-liter 911 SC engine for Japan
For the best wipersblades in The Netherlands and Belgium: www.nieuweruitenwissers.nl
Old 07-25-2014, 10:00 AM
Its definitely 06. Maybe not clear in the pics but it's a 6.
Old 07-25-2014, 10:25 AM
Champagne on Beer Budget
HelmetHead's Avatar
RedBook says its from a 68 911 coupe #3280001-3281606 (901/14) which is probably what you have already found. Could it be a replacement case restamped to earlier number?
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 07-25-2014, 10:28 AM
I have no idea what it could be Haha. I'll tell you (although I come from 2 944s), it's got a lot of pep.
Old 07-25-2014, 10:32 AM
Post number 6 here is my situation: Engine number question 74 911S targa
The case may be from 68, but if that's the case then it was restamped 930/06? Making it...? Unknown without a teardown?
Old 07-25-2014, 02:35 PM
Ah hah! Notice under the slash in 930/06, there's a 9 ground off.
New theory is a service part restamped
Old 07-25-2014, 07:50 PM
Pulled the motor out for valve adjust.
It has 4 journal cams which I'm told makes it 3.0
2.7 distributor and cdi box. I'm still in the process of learning about 911 motors, and this one's thrown me for a loop!
Old 07-27-2014, 10:36 PM
E Sully's Avatar
The 930 101 103 4R casting number would be SC. Serial number makes no sense. Case would not be a Porsche restamped '68.
Tom Butler gives a nice overview of engine cases.
r case designations
Ed
1973.5 T
Old 07-31-2014, 08:28 AM
It's clearly NOT an early chill cast case because the longitudinal fins are missing, among other details. The casting number is wrong, too. It has a 2.7 exhaust system (one of the worst available) I suspect the numbers have been altered, or possibly it was an unnumbered case that had numbers stamped to suit the needs of the person who installed it. I think the 930/06 is authentic, I doubt the actual serial number is. Per the specs book, all 6 cylinder engine serial numbers of that era should have as the first digit a "6". This is clearly a "3". The second digit is a "2", indicating a ROW engine, the third an "8", indicating a 1978 model year. The last 4 digits indicate the "0888th" engine in the series.
The Cap'n
Old 07-31-2014, 09:46 AM
gearhead
Made on a Friday after lunch. Too much beer in the stomach of the tech who stamped it.
Old 07-31-2014, 10:03 AM
Finally some answers!
Those dang Germans
Old 07-31-2014, 10:46 AM
The Cap'n
What you might have missed is that right under the slash in 930/06 is a partially removed 9, leading me to believe THAT was the restamped number. But I could be wrong
Old 07-31-2014, 10:49 AM
E Sully's Avatar
The 930 101 103 4R is part of the engine case original casting, but all other stamped numbers are suspect.
Any chance it was a '77 3.0 Carrera case?
Ed
1973.5 T
Old 07-31-2014, 11:19 AM
I seem to have a faint memory of engine serial numbers preceded by a star indicate blank case stamped as replacement engine?
Old 07-31-2014, 12:03 PM
