Cool thanks, I just OHM'd out the sensors, and they're good. I ordered the light from Amazon it'll be here in a few days, and we'll see what we have then, beginning to suspect computer, as everything else seems good. It's that or fuel pressure, as I've not validated that, I would think that if I let the pump build though (Since it runs with the key in run, and not just when the DME tells it to, have to fix that one day) it would at least sputter or cough.
Also I noticed the tach doesn't move when it's cranked, is that important.
1971 911T British Racing Green 3.2L 2013 981 Boxster S Aqua Blue/Grey 2014 981 Cayman S Agate Grey/Black enjoyed and passed along: 1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A |
Electronically all three (tach, injectors, coil ) will work once the sensors see flywheel motion. The tach isn't always good enough to show the ~200 RPM during cranking though. So I'm not sure I'd put too much into that observation. Let's see what the NOID light will tell us.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Noid light shows injectors not firing, next up trying to check grounds
Injectors don't need GND. They get +12V from DME relay and GND pulses from the DME. If the coil works your GND to the DME is fine.
You start to narrow issues to the DME. Send me a PM if you need it checked/repaired. Ingo
I'm going to try my dme in another car first, I have a spare but don't want to blow that up, what can kill a dme?
DME killers would be shorts in the harness (injectors, coil) or a miss-wired tachometer
Hmm, seems unlikely those would have cropped up in a car that's been running for 20 years but that's where I'll look. I'm going to try my ECU in a friends car this weekend, and go from there. Is it more likely it just failed or that something killed it? I'm also thinking I should trace the harness for the injectors back and make sure it didn't just come unplugged, the engine was out earlier this year, it's seen 2 tracks days and maybe 200 miles of street driving since then but we could've screwed something up when it went back together.
can damage the DME control unit's injector output resulting in no injector signal.
Dave |
Has anyone mentioned to check for tightness the ground connections on the intake manifold above #1 cylinder? A number of them come together there. Saw this happen before. Wasted a lot of time doing a lot of checks. Problem solved by simply tightening the ground connection. Duh.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
When mine exhibited those symptoms, it turned out to be the 12v power to the DME fuse. It had worn thru the metal on the top. Replaced the old fuse and haven't looked back.
Where can I measure for 12v to the DME At the relay or pull the power on DME? Would this be the case if I have spark and it cranks?
For grounding I attached some jumper cables to that bolt on the runner and ran it tot he front of the car where the batteries - terminal are attached to the chassis, no difference so I doubt it's a poor ground. I'd check alternator but how do I do that when the engine won't run? It won't be measurable while cranking!
1971 911T British Racing Green 3.2L 2013 981 Boxster S Aqua Blue/Grey 2014 981 Cayman S Agate Grey/Black enjoyed and passed along: 1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A Last edited by gremlin; 10-15-2015 at 10:34 AM.. |
One shorted injector will take out the other 5 because all 6 are wired in parallel. I suggest you unplug the injectors on the LHS cyl1-3 and see if it attempts to start. Basically you are eliminating the 3 LHS injectors to see if she starts. Then do the opposite RHS the same way. If you find that disconnecting the LHS injectors now allows the engine to start then one of those 3 are shorted, continue plugging them in one at a time till you find the shorted injector.
I mention the above because you already said you can't detect injector pulses with a noid light. You can also try the noid light test again but unplug all injectors except just 1, and test at that 1 injector to see if you now have pulses. I don't see this as a common problem but I have seen it a few times.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 10-15-2015 at 10:59 AM.. |
if the alternator is intermittent. But if the DME ECU's injector output turns out to be your injector problem, an intermittent alternator can cause that. As mentioned, a shorted injector/injectors or wiring can cause the same problem, but it's rare.
Dave |
Thanks I'll check these things next. Seems like all I've got left are rare failures, as I've already found the common ones are good.
Make sure the up-shift wire from the control unit (pin 11) is not being used nor connected incorrectly as this will also damage the injector output.
Dave |
Has anyone checked the flywheel sensors. I had one of mine fail so I put in both new to head off any future issues as they were a fita to replace....Put them in and it fired right up! These are either good or bad no in betwen...If there is no signal to the DME from these sensors the DME will do NOTHING, frustratinf when it happens suddenly.
Jay Traner 1984 911 targa 1923 STuTZ 690 Touring 2014 VW CC 2.0T 2021 Subaru Forester (Mrs) |
Yup above in thread plus if either of those fail you won't get spark. I haven't checked CHT sensor just yet, so I'll also do that but next up is looking for a shorted injector. I doubt that the upshift wire is the issue as the car's run in this configuration for 23 years now...
Brew Master
You need to be very clear on what works and what does not. If you have spark then both crank sensors are working. So if you have spark but no injection pulses we know it's something in the injector drive circuit or the injectors. I test for coil and injector pulses with a simple LED test light, you can get one at Walmart for about $5.00 but it MUST be the LED type. Just unplug an injector and put the light across the 2 pins in the injector harness and have someone crank the starter, the LED must flicker if you see no LED activity you have no inj pulses. You can use the same test light across the coil's '-' and '+' posts and it will also flicker if you have coil pulses. The LED test light can even be used to test both crank sensors, unplug each sensor and put the light across the pins that go to the sensor, then crank motor and again the test light must flicker.
Where are you located?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 10-16-2015 at 06:25 PM.. |
