'87 3.2 G50 - rough idle/stumble when accelerating
My car seemed to just develop this problem that I THINK has gotten progressively worse. Symptoms as follows:
* Rough idle, either hot or cold. It's idling very low, like 600 RPM, a lot of hunting - nearly stalls (has stalled a couple of times but it's rare) and occasional popping
* On acceleration, there is a hesitation or stumble. It's like how it feels when the engine is lugging at low RPM. It seems that I get through a particular stumble and the engine is OK again... it's hard for me to tell if it's making full power, but at least some of the time, it pulls like a freight train
Some things that have recently been done:
* New cap and rotor. Smoothed out the engine a lot but didn't solve the problem
* New air filter
* 3 tankfulls of gas with a bottle of Techron in each
* Took apart AFM and bent the wiper arm to ride in a new arc. Old one had a couple of bare spots, but I've seen worse in other threads on this forum
I have a new O2 sensor on order, should arrive today. I'll install that and see if it helps at all.
But I'm looking for other ideas. Any ideas on where else I should start?
-Glenn
Old 07-30-2014, 12:47 PM
Just another observation.. the stumble happens at full throttle, too - althought it seems, less frequently. Doesn't that mean it can't be the O2 sensor?
-Glenn
Old 07-30-2014, 12:58 PM
p.s. the car has 234,000 miles on it, 10,000 of which were done by me over the last 7 months, in sheer bliss
Yes it runs
tsiegwart's Avatar
Send a message via AIM to tsiegwart
If you unplug the O2 sensor and it smooths out, you will know it's the O2 sensor. It switches to a different mode of control in the ECU. If you unplug it and it doesn't smooth out, it's something else.
Another suggestion is new wires. Also temp sensor. I don't know of any tricks to test that.
Todd, Minneapolis
1987 Targa
TargaBlog http://tsiegwart.wordpress.com/
32C #4
Old 07-30-2014, 01:01 PM
Ok. That's an easy enough thing to test, thanks.
Old 07-30-2014, 01:02 PM
Yes it runs
tsiegwart's Avatar
Ah!! Full throttle stumbling would indicate it's not the O2 sensor. The "wide open" sensor takes the O2 sensor out of the mapping equation.
Todd, Minneapolis
1987 Targa
32C #4
MBruns for President
JeremyD's Avatar
I had this issue on my old 3.2 - I changed the coil and the plug wires and it went away. Definitely seemed to be ignition related,.
Old 07-30-2014, 02:35 PM
Bye, Bye.
Scooter's Avatar
+1 on the O2 advice above. I would also change plugs (wires and/or coil?) to go with that new cap and rotor.
Elvis has left the building.
Old 07-30-2014, 02:48 PM
Another possible clue: There is no fast idle. The pattern of it starting around 1000-1100 rpm and then selling down to 800 isn't happening anymore. Does that mean anything?
Old 07-30-2014, 03:23 PM
Found the problem! One of the plug wires wasn't fully seated. What boneheaded did that?!?! Oh wait a minute... That was me :-/
Well I just fixed it and took it for a drive, and OMG, what a car. The sound of the engine echoes in my head even after shutting it off... Wow.
Thanks all!!!
Old 07-30-2014, 07:06 PM
Just not nearly as badly as before. Is it possible the plug has been fouled?
Old 07-31-2014, 06:40 AM
Not sure what happened with that last post... What I meant to say is that, while it is MUCH better, still a mild stumble happening. Is it possible the plug is fouled?
Sent from my RM-877_nam_att_205 using Tapatalk
Old 07-31-2014, 06:55 AM
Bye, Bye.
Scooter's Avatar
I would just change the plugs. Cheap and easy...and just good maintenance.
Old 07-31-2014, 07:54 AM
TheSt|G's Avatar
Change the plugs. Costs what, $20? Check to make sure you have the wonderful Porsche specialty tool first.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 07-31-2014, 08:35 AM
is this the tool? 1987 Porsche 911 Carrera Coupe - Ignition - Page 2
Old 07-31-2014, 08:53 AM
sorry, bad link. Is this it? Pelican Parts - Product Information: TOL-SK4490
Old 07-31-2014, 08:56 AM
997Sbeebe's Avatar
they're probably referring to this tool - in your tool kit.
'04 GT3
'97 C4S
'90 C2
'86 951
Old 07-31-2014, 09:54 AM
Oh. I do have that. Wondered what that was...
Old 07-31-2014, 10:14 AM
VMAX1's Avatar
You probably need to check for vacuum leaks, while your back there. A ton of threads on that. If you haven't got the Bentley, you might want to invest in one.
Old 07-31-2014, 11:06 AM
Member 911 Anonymous
DRACO A5OG's Avatar
You probably did this, but did you replace the Fuel Filter?
'85 Carrera Targa
PCA/POC
Old 07-31-2014, 11:46 AM
