Garrett's Avatar
anyone ever replaced pre-68 front a-arm bushings? Need some help...
I have removed the front suspension off my 65 911 and cannot get the rear bushings off the front a-arm assembly. Is there a trick to this? The a-arms are stuck into the crossmember and won't budge so I can get at the bushings.
And, where can I buy replacement bushings for these old cars? None of the parts warehouses carry them. Any info would be appreciated! Thank you.
Old 09-29-2002, 04:41 PM
Chuck Moreland's Avatar
Do read this:
Replacing front suspension bushings
and this:
Suspension bushing, the right way
Pelican sells the bushings.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-29-2002, 07:13 PM
Nobody
bob tilton's Avatar
propane torch! apply heat to the bushing for about seven minutes til you can hear it "fizzle" and it will pop off.
bob
68L
Old 09-29-2002, 07:17 PM
atlporsche's Avatar
I used the Heat and Beat method as well in my '67. The rust inside had bonded with the rubber...bad deal there...but it's all clean now...
I had a machinst friend make some poly bushings up for me...
sjd
Old 09-30-2002, 03:21 AM
