NYSCAR's Avatar
Send a message via AIM to NYSCAR Send a message via Yahoo to NYSCAR
Funny steering problem
Hi all,
I need some advice. I've noticed my car handles poorly, feels like the front end is out of alignment. This behavior seemed to start after I took the car to have turbo tie rods put in and alignment done. Could be a coincidental pot hole, but I also think it could be a bump steer issue. Could changing to turbo tie rods case bump steer problems? The ride height hasn't changed at all. I called the mechanic and he said that changing the tie rods wouldn't have anything to do with bump steer issues.
Thanks,
Brad
73 911S Coupe sold
Old 09-30-2002, 10:17 AM
NYSCAR's Avatar
bump *no pun intended*
73 911S Coupe sold
Old 10-01-2002, 03:26 PM
PRO Motorsports
Tyson Schmidt's Avatar
Did you have your car aligned after the tie-rod install?
Your mechanic is right. No effect on bump-steer. Only if you lowered the car at the same time.
If the front toe is off enough, (and it usually is after new tie-rods and no alignment) the car will have a mind of it's own in the steering department.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-01-2002, 09:41 PM
dickster's Avatar
what are the symptoms??
Rich
'86 coupe
"there you are"
Old 10-01-2002, 11:40 PM
You toe is out of alignment since that is the only parameter that changes when new tie rods are installed.
Cheers,
Joe
Old 10-02-2002, 12:10 AM
NYSCAR's Avatar
Thanks guys, I was just wondering about the bump steer thing. Symptons are the car feels really unsteady in the curves, more so on right hand turns than left hand turns. Not confidence inspiring at all, where as before I could rip through curves with great pleasure. The mechanic said they did an alignment, so i guess it might be something else. Oh also I occasionally hear a knock sound from the front suspension, not sure what it is. I checked to see if the sway bar links had snapped from the control arms and were swinging around, but they look just fine. I guess I'll just take it to a shop and have the alginment checked out again. I'm no expert on suspension problem diagnosis, but I'm learning anyway
Brad
73 911S Coupe sold
Old 10-02-2002, 08:41 AM
Senior Member
Superman's Avatar
Here's what I would do. Given the noise, I would raise the front of the car and perform as good a personal inspection as I could, to ensure my safety on the following drive. Then, I would drive it to the same shop that did the work, and tell them the same stuff you posted here. Sounds like the alignment is off. Don't take "no" for an answer.
Mocha 1978 911SC. "Coco"
Old 10-02-2002, 09:51 AM
Send a message via AIM to Oldporsche
Cool
Please check your lower A-arm mounts very carefully. I had that same feeling one time. A check revealed that the mount area of the lower pan had separated. I had to replace the lower pan.
Good luck,
David Duffield
Old 10-02-2002, 09:58 AM
