-   -   Newbie engine teardown/rebuild - advice always welcome! (http://forums.pelicanparts.com/porsche-911-technical-forum/824637-newbie-engine-teardown-rebuild-advice-always-welcome.html)
kcheves 09-06-2014 01:28 PM
Originally Posted by GT2BH (Post 8248568)
Thanks SmileWavy
On a different topic, here is a friends mint 1973 2.7 RS
http://i306.photobucket.com/albums/n...ps2e5046d3.jpg
and my other Porsche with its big brother, also owned by the same person
http://i306.photobucket.com/albums/n...ps1e82d8ec.jpg
Wow, a GT1. Only one I've seen in person was at the Porsche Museum. Very rare and beautiful.
fritzgator 09-06-2014 06:24 PM
Looks like a combination of grinding marks and impact damage. As far as rebuild goes, post a callout to european pelicans for shop recommendations. If i could afford the rebuild i wanted, which is still fairly modest, i would do 3.2SS,with PMO carbs and whatever cam grind best suited for that setup. Maybe PMO's EFI setup if i had More knowledge on such things.
GT2BH 09-06-2014 10:28 PM
Should I be concerned with the marks?
I am inclined to keep the CIS, don't want to go overboard.. especially that I'm spending quite a bit on new fuel lines, new oil lines and cooler (Elephant Racing), etc.. Maybe the next stage..
I'm going to start putting my shopping list together now.. If you had to set a budget for a new rebuild, what would you ideally be looking at?
GT2BH 09-06-2014 10:30 PM
The GT1 actually hit the track that day.. so did the 2.7.. and many others from their collection.. it was a great day.. I'll post more pictures when I'm home
fritzgator 09-07-2014 06:35 AM
Just check to make sure there aren't any burrs that could break loose later,other than that it looks ok to me. Search 3.2ss or ss3.2 for alot of info on variety of intake options. Did you even mention going 3.2 or is that me just projecting? If staying 3.0 i think cams, distributor recurve, CIS and headers(guessing you'll pass on heat exchangers) would be best $$ spent. Keep in mind that all my input info was garnered here on pelican, and there are many people here with actual experience with these matters. I'd Start a separate thread asking for options.
GT2BH 09-07-2014 07:12 AM
All options are open at the moment. I am looking a budget of $10k, give or take, and up for suggestions. Typically with any project, you start thinking one thing and slowly end up changing your mind :) I have been researching the 3.2 conversion and there is a lot of information, but my problem is I have no access to a good, reliable machine shop locally. I contacted the main machine shop and they said they don't have people available to disassemble, they will only do the machining.. I am not very comfortable with that.. yet I don't want to replace everything if my parts are fine or need minor machine work..
It's a bit of a mess but I'll get through it.. all guidance says I will need to replace my alusil cylinders so I'm looking at taking the leap to 3.2..
RDM 09-07-2014 11:14 AM
I've seen a number of threads where members report success at reusing Alusil cylinders, including a very long thread that discusses DIY reconditioning. But if you're looking for a pretext, this will do!
Edit: Here it is: http://forums.pelicanparts.com/911-engine-rebuilding-forum/137346-re-ring-alusils.html
GT2BH 09-07-2014 07:13 PM
Thanks Dru - I'll go through it today.
Do you recommend any machine shops in Germany that I can ship my stuff to? I was in Dusseldorf a couple of months ago and visited a few places but I didn't take down any details :(
KTL 09-08-2014 08:34 AM
Looks like you had some cylinder leakage at cyl. #3, due to all the crud around that area of the case. Maybe when the studs were replaced, that cyl. was not sufficiently tight. If you have all steel studs, your engine has been serviced above the case at some point. The SC engine originally came with steel upper, dilavar lower studs.
Case looks REALLY clean inside which is nice to see. Bearings look to be in good condition from a far distance.
I wouldn't bother taking apart the cam towers down to the bear minimum. Only need to remove the rockers & shafts and the camshafts for a thorough inspection & cleaning. For peace of mind you can pull out the aluminum end plugs and run a nylon brush thru the spray bars to clean out any crud in there. Also inspect the oiling holes by fishing some stiff wire thru each hole. NO reason to fully remove the spraybar if you do not truly need to do that.
GT2BH 09-08-2014 08:39 AM
Yeah the crud looked like it was concentrated around cyl 3, and as I mentioned earlier some studs were really easy to remove. Whoever did it before was probably sloppy. The case opened up real quick like there wasn't any sealant applied before.
So you don't think I should consider replacing the valve springs, etc? I'm considering sending my heads for proper inspection and machine work to the US but it'll cost me dearly, so I want to make sure I get full benefit
KTL 09-08-2014 08:47 AM
Porsche original valve springs are really good but nothing lasts forever. They had some problems with broken valve springs in a small number of SCs but otherwise they have been great. So, no, I don't think replacing the springs is an absolute must. Especially not on a stock engine refresh.
Well the case should take some effort to pop it open. I don't see much of any orange Loctite 574 sealant on either of your case halves. Did you already clean the residue off or is it pictured exactly how it came apart? If there's no signs of orange sealant, someone has previously opened the engine case. And those marks inside the case would lead me to believe someone has been inside it before.
If you send them to G2 Performance in Michigan (cgarr here on the forums) he can do all the assembly work on the heads. So you don't need to disassemble them.
GT2BH 09-10-2014 08:22 AM
That picture of the case is 5 seconds after I opened it. I am sure this engine was messed around with before since I noticed alot of irregular bolt and nut sizes. There is no sealant as you can see. This is why I don't want to take a chance on the heads or the springs since I really don't know what the engine has been through.
I got some stuff in the mail.. it seems the cart arrived before the horse
http://i306.photobucket.com/albums/n...psdfqa0xeh.jpg
KTL 09-10-2014 12:05 PM
Understood on the history. But if there was no sealant used, the case parting line would be extremely leaky. I don't know what was used to seal it, but it must have been VERY thin!
If you want to get new valve springs, that's understandable. Porsche factory valve springs are really good springs so do not hesitate to get new OEM Porsche springs.
What is the black Permatex sealant going to be used for? I would recommend against using it to seal the case thru bolts like shown in the 911 Engine Rebuild book. That is a very messy/sloppy way to seal the thru-bolt o-rings and captive washers.
The best way to ensure the o-rings seal is to make sure the o-rings have enough room under the captive washer and are not crushed by it when the bolt is tightened. There is a massive debate that went on not long ago about how to seal the thru-bolts properly.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/452985-your-opinion-wanted-green-bolt-through-viton-o-rings-rtv.html
I'm of the opinion that the correct o-ring (green type) lubricated with special grease, oil, DowCorning 112 paste (or similar silicone paste) or whatever lubricant you choose, and a slight countersink in the case thru-bolt holes is the right way to make sure those o-rings are not damaged and seal properly
GT2BH 09-11-2014 01:06 AM
The case was pretty leaky, that is a primary reason why I decided to do a full teardown.
I bought all the items on the shopping list as per Engine Rebuild book. I will go through that thread and make sure to do it in the best way possible, thanks for pointing me in the right direction!
I dropped a PM to cgarr and he came back to me with some good advice. I will know more this weekend once I remove the rockers, shafts and camshafts for inspection. Will post more pictures soon.
GT2BH 09-12-2014 06:54 AM
OK - rockers removed, heads separated, camshafts out, and rods removed.
Now, lets play "Normal or Not", starting with the obvious one
http://i306.photobucket.com/albums/n...psasnmrbqb.jpg
http://i306.photobucket.com/albums/n...psikokqi0b.jpg
Not sure where that piece of plastic came from!
http://i306.photobucket.com/albums/n...ps7se5izny.jpg
Now, rod bearings
http://i306.photobucket.com/albums/n...ps3os0lnuq.jpg
http://i306.photobucket.com/albums/n...ps9wuuolvj.jpg
http://i306.photobucket.com/albums/n...psxqakwmre.jpg
Camshaft
http://i306.photobucket.com/albums/n...psjno17uqj.jpg
http://i306.photobucket.com/albums/n...psfodypq5d.jpg
http://i306.photobucket.com/albums/n...psrnb7e7nq.jpg
GT2BH 09-12-2014 06:55 AM
Heads
http://i306.photobucket.com/albums/n...psy3gvye3i.jpg
http://i306.photobucket.com/albums/n...pszgm1tiio.jpg
For the Cyl 4,5,6 heads, one of each exhaust stud has white material on it
http://i306.photobucket.com/albums/n...psfko5bilw.jpg
Despite the rod bearings, the crankshaft looked OK
http://i306.photobucket.com/albums/n...pszig2dgpc.jpg
http://i306.photobucket.com/albums/n...psfihv9r7x.jpg
http://i306.photobucket.com/albums/n...pstdieokcx.jpg
GT2BH 09-12-2014 06:58 AM
and one thing I found strange. While all the rocker bolts I removed were lubricated, the cyl 4 intake side bolt was rusted and dry
http://i306.photobucket.com/albums/n...psp4vpjcca.jpg
GT2BH 09-12-2014 07:40 AM
Just weighed my rods, they were (in grams), 745, 745, 740, 744, 745, 744. 5 grams off the 3rd one, which had the worst bearing pictures above. Should I be concerned?
KTL 09-12-2014 07:50 AM
Those rod bearings are a mess. The crankshaft may look good by eye but run your fingernail across the surfaces. If you can feel ridges with your fingernail, the crank needs to be polished.
The rocker shaft bolts were lubricated because the rocker shafts were not sealing well in the cam housing. They all should be dry.
The camshafts are pitted likely from using oil with not enough extreme pressure additives (zinc/ZDDP) but luckily they can be reground. Dougherty Racing in CA can regrind them for you to stock SC or 964 specs. 964 is a very good choice for rebuilding an SC engine.
No surprises really in the combustion chambers or ports. Pretty common for valve guides needing replacement. They don't look bad so they might have been replaced previously, as evidenced by the head studs being all steel instead of half being dilavar.
The weights of your rods are OK. The Porsche specs says the max variation in a set should be no more than 8 or 9 grams (going by memory here) so you're OK.
GT2BH 09-12-2014 08:04 AM
Thanks Kevin - what do you think caused the damage to the rod bearings? does crankshaft polishing have to be done professionally? That'll mean I will also need to ship it out :(
I spoke to Dougherty and will hopefully get the cams reground to 964 specs. If shipping isn't reasonable then I'll just buy a new set.
Strange about the rocker bolts.. instead of 1 being the problem, it turns out all were the problem except 1.. I'm sending the rockers out for inspection as well..
So, now that everything is apart, what should I have done to all these parts to make sure I have many happy miles? Plan is to send the heads and rockers to a reputed machine shop, camshafts to Dougherty (maybe), and keeping my rods but ordering new rod bolts.
KTL 09-12-2014 12:40 PM
Yes crank polishing needs to be done professionally.
One set of rod bearings looks like typical wear, although very worn due to hard use and possibly thin oil allowing contact with the crankshaft at high rpms. The speckled rod bearings look like failure of the bearing material itself coming loose from the bearing shells.
cgarr can do the rockers if you plan to send him the heads too. He does a nice job refacing the rockers and also installing a low friction bushing in the rocker bore. We have used them in our racecar engines with good results.
I don't think you need to do anything special to the parts prior to reinstallation. The rods should be checked for their bore dimensions, especially since the rod bearings look bad. New rod bolts are a must since the old bolts must be discarded- they are a one time use stretch bolt. ARP rod bolts are a good choice since they are not much more expensive than a set of new OEM Porsche rod bolts.
zelrik911 09-13-2014 05:21 AM
Can you tell if the bearing shells are the 'original' Porsche or a replacement like Glyco, are there markings on the backs?
That chunk of plastic under the valve is a real mystery - could it be a piece of the CIS airbox that fell into one of the ports?
Peter 78 SC 3.0
GT2BH 09-13-2014 06:51 AM
I'll have my rods looked at by Rennsport and make sure everything is within spec. I ran my fingers through the crank and couldn't feel any scratches or anything uneven in the surface, but I'll see if I can get it polished locally.. if not, whats the worse than can happen if I clean it myself with carb cleaner and leave it alone?
GT2BH 09-13-2014 07:14 AM
Peter 78 SC 3.0
My thought is thats its a piece from the airbox. I will take apart the CIS soon for inspection and will check.
This is the back of the failed bearing.. notice the corner is chipped
http://i306.photobucket.com/albums/n...psunpvwyrp.jpg
zelrik911 09-14-2014 03:13 PM
Bearing moving inside rod??
I am no expert but it looks like the bearing may have been moving inside the rod.
Was it the locating tab that has been broken off at the corner?
Perhaps some more experienced people can give an opinion on this and the origin of the bearing shell.
Peter 78 3.0 SC
GT2BH 09-14-2014 09:25 PM
Peter 78 3.0 SC
Close inspection of the crank doesn't show signs of the bearing having moved - even when I touch it - but I'm no expert either. And yeah, the locating tab was broken off :(
Originally Posted by sjry6uj (Post 8262088)
Post a close up picture of the engine harness. Looks like there are some spliced wires visible. Not a good thing. http://lifehealthus.com/image/images/37.gif
Not too worried - getting a new harness from Timmy2
timmy2 09-14-2014 09:57 PM
LOL, your thread has been spammed by a bot. Even Wayne's shipping thread was hit the other day. :)
GT2BH 09-14-2014 11:12 PM
That's a very smart bot!
timmy2 09-14-2014 11:25 PM
Not really, they copy someone's post in a thread and repost it. This one happened to be mine from page one.
See it all the time, Pelican is a popular site.
Notice it is gone already since I reported it. :)
KTL 09-15-2014 06:30 AM
Original Porsche are Glyco. So the branding isn't a way to tell originality. Need to look at the date code stamping on the bearing shell.
Once the bearing wants to move, it's going to spin and then the bearing gets completely smeared. Those bearings haven't spun, but they sure do look crappy. Somebody may have scuffed the back side of the bearing to remove the plating and give the bearing some bite in the rod?
If you can't feel any ridges in the crank with your fingernail, you're probably OK. Just clean it up with solvent and then treat it with rust protectant or motor oil. DO NOT leave the crank dry or it will rust very quickly.
GT2BH 09-15-2014 08:24 AM
Thanks K - I haven't wiped it down yet but I will make sure its always oiled up
That was the only bearing which was completely gone - I am told it might be an oiling issue. I'll be packing everything up this week and shipping it out for machining and will order all the other necessities as well. Now the waiting begins (and the money is spent).
GT2BH 09-16-2014 06:10 AM
Can anyone confirm whether these are the original or upgraded chain tensioners?
KTL 09-16-2014 06:20 AM
Those are the later style oil pressure-dampened "Carrera" chain tensioners.
GT2BH 09-16-2014 09:05 AM
Thanks! So all I need to do is replace the cam oil lines and I'm good. I am stressing out about my shopping cart, don't want to miss anything
KTL 09-16-2014 09:11 AM
Are any of the oil lines leaking? If not leaking, it's OK to re-use them. The pieces associated with the oil lines that are good practice to replace are the aluminum sealing rings and the o-ring on the tensioner "snout" where it is fed the oil.
The o-ring is just for splash sealing the tensioner snout to the chain housing cover. The seal rings are most important. However they can be re-used in a pinch. Only when the seal rings are really smashed (from over-tightening) and grooved are they risky of leaking.
GT2BH 09-16-2014 09:30 AM
Thanks again K. My lines weren't leaking but it would be worth while for me to check them again and make sure there are no issues. I'm order a full gasket kit from our host, I'll check again if it includes all the necessary o-rings
GT2BH 09-17-2014 11:44 AM
Update:
I've packed up the stuff and the heads/rockers are going to Craig (cgarr), rods are going to Rennsport and cams are going to Dougherty. Rods will get checked and ARP bolts installed, and the cams will be ground into 964 specs.
I've placed an order for the 100mm cylinder with 9.5:1 JE pistons from LNEngineering and they've shipped. Craig will take care of the heads to match.
Big order pending from Pelican, hoping it'll be placed by Friday. The tools I've ordered a few weeks ago from Pelican are incomplete and they are ignoring my request to ship partial shipment and leave the last tool until it arrives. I'm annoyed.
tharbert 09-17-2014 02:08 PM
If you have the rods done, rebushed and big end trued, the machine shop will need the old rod nuts/bolts. They are not useless yet. Great progress!
GT2BH 09-17-2014 09:09 PM
I re-assembled the rods and packed them, so they include the old nuts and bolts ;) thanks for the input
GT2BH 09-19-2014 10:03 AM
I started looking at the CIS today, changed a few vacuum hoses and cleaned the plastic bits. What are the main areas I should be tending to while the engine is out? The only issue I had before taking the engine out was that after my MSD installation my idle was at at about 1.5k RPM.
