Sway bar hardware?
I have a 76 911s with front and rear anti sway bars. What is the proper length and grade bolts to hold them up and what kind of washer should I use. Thanks
Not sure of the length but SAE grade 5 or Metric 8.8 is what is typically used.
Look in the PET for the length. Pretty much all specs are given. Flat washers are generally fine for that application.
-C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
