Battery cables warm, is that normal?
Noticed that the 3 medium red wires coming off the positive battery terminal are warm/hot. Never noticed that before. Fuses are fine, not blowing.
Car keeps cutting out ( seperate thread), trying to exclude this as a clue.
Is this normal? I plan to look for shorts, but for all I know this is normal, and I just noticed.
Before I start looking for issues, can someone let me know if this is abnormal?
Thanks.
Old 08-04-2014, 01:33 PM
wolds's Avatar
I don't think it's normal, maybe others can chime in. I'd be looking for possible suspect grounds and other areas of increased resistance (connectors, fuse block, etc.)
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 08-04-2014, 01:44 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Cables.
Thanks.
M/Y please.
pm me as needed.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-04-2014, 02:15 PM
1988 930... It has the 3 red wires coming off, 2 are paired. I understand these feed the fuse box, alternator, and ignition. I plan to look for shorts when the weekend comes up, assuming this is abnormal.
Any reason 2 of the wires are joined, and 1 is by itself?
Thanks for the input.
Bo
Old 08-04-2014, 02:19 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Heat means resistance!
So...if any wire is hot..it can be one of two things....wire too small for current flowing....or....connectors not flowing 100% (resistance in the connector joint).
My look on it...figure out how much current is going to go through the wire...check the chart for wire guage needed and length of run...then use next bigger size just to be sure.
Also...make sure your switches are clean and working properly.
Bob
Bob Hutson
Old 08-04-2014, 03:12 PM
ROW '78 911 Targa
timmy2's Avatar
Clean up the connection to the positive and negative terminals as well as the main negative cable ground point, apply no ox grease and see if it goes away.
Old 08-04-2014, 03:57 PM
Wires.
Bo
The red wires terminate at different bus locations on the fuse panel.
1986 911 Targa.
Only in L.A.:
Old 08-06-2014, 09:56 AM
Please see my other thread, on my car running super rich.
Turned out the thicker of the three wires was getting super hot. Friend recommended changing the crimp on the end. I took off the heat shrink, and the wire was very frayed. I changed the connector, and it seems my running problems all went away. I hope.
Thank folks, glad it was something simple...
Bo
Old 08-17-2014, 04:11 PM
ROW '78 911 Targa
timmy2's Avatar
Just read your other thread in the turbo section.
Too bad you didn't mention the ends of the cable turning black in this thread, that was a big clue.
Anyways, glad you found it.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-17-2014, 04:47 PM
