Egr plugs 77 911
Anyone know if Pelican sells plugs for the egr system on a 77 911? Looking to take it out and plug the holes in the exhaust.
Cheers, Jon |
I don't know where you buy them. My '74 has the ports plugged with a plug that is flush mounted and has an allen head.
Fleabit peanut monkey
FWIW, Believe you are talking air injection, Not exhaust gas recirculation.
No biggie. Air injection requires the "power robbing" pump. EGR dumps inert exhaust gas into the combustion chamber (via intake) only when you are cruising at highway speed and stifels (Stifel, Edith) oxides of nitrogen from forming. One of the better emission thingies. That said, take you time finding the right part and listen to those who know about these plugs. I don't know for sure but are they a tapered, pipe fitting plug? Makes them easier to remove. Also, earlier 911's don't have EGR.
1981 911SC Targa |
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Excellent, thanks for the link... So these plugs are for where the Smog Air Pump connects to the exhaust. As for the EGR, I've already capped off the EGR and where it connects to the throttle body, but I'd like to remove the pipe from the engine compartment to the exhaust and plug that hole too. Any plugs available for that purpose?
Cheers, Jon |
