-   -   CV Axel boot slung grease (http://forums.pelicanparts.com/porsche-911-technical-forum/826413-cv-axel-boot-slung-grease.html)
Rodek 08-21-2014 01:46 PM
The CV Axel on my driver's side decided to sling grease out of the outer boot. Can I replace a boot on this car or should I go ahead and replace the axel or...both axels? Your suggestions are greatly appreciated.
dicklague 08-21-2014 01:49 PM
Axle boots
You can replace just the boot....you do have to remove the CV joint, and then replace the axle boot.
Rodek 08-21-2014 02:00 PM
Thanks for the quick reply! I failed to mention that the car is a '78 SC....if that makes a difference or not, I'm not sure.
Jdub 08-21-2014 03:29 PM
Actually yes, it does, depending on your current mileage and known replacement dates for your axles. If you have say over 135K on an original set of axles I would have them replaced. Many will suggest regreasing the existing, and that can work. But I found at 145K, even after rebuilding the old bearings, the best solution was to replace the bearings at a minimum (and for you, replacing that essential boot that keeps the road crud out).
Rodek 08-21-2014 05:21 PM
The car has the original axles and has about 143K on the clock. I think it would be best to replace both in my case. Now about these bearings you speak of, is this something that requires maintenance in addition to the axles?
Rodek 08-22-2014 07:31 AM
Can anyone help me understand these bearings mentioned above?
88911coupe 08-22-2014 07:58 AM
I assume they are referring to the Constant Velocity (CV) joints at each end of the axle. This is what allows the wheel to move up and down and the axle moves with it. Many will just remove the old boots and clean up and then regrease the parts, assuming they are not worn or pitted. I did this about 40,000 miles ago on my Carrera and so far (200,000 miles) they are working fine. At some point I'll probably have to replace them. There are a number of threads on this subject, just do a search on rebuilding cv joints and you'll see what I mean.
Rodek 08-22-2014 02:26 PM
Thank you for the education on cv joints. I'll do a search on rebuilding them and see what I come up with.
JJ 911SC 08-22-2014 04:05 PM
Originally Posted by Rodek (Post 8226463)
Thank you for the education on cv joints...
Just not yet. Once you read the 400+ post of this one you will be ready for a DIY :D:):D
http://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints.html
Rodek 08-22-2014 06:23 PM
Oh my! You're right! Lots of info from the link you posted. I'll get to reading more right away. Thank you!
