Rodek
CV Axel boot slung grease
The CV Axel on my driver's side decided to sling grease out of the outer boot. Can I replace a boot on this car or should I go ahead and replace the axel or...both axels? Your suggestions are greatly appreciated.
Old 08-21-2014, 12:46 PM
Axle boots
You can replace just the boot....you do have to remove the CV joint, and then replace the axle boot.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 08-21-2014, 12:49 PM
Rodek
Thanks for the quick reply! I failed to mention that the car is a '78 SC....if that makes a difference or not, I'm not sure.
Old 08-21-2014, 01:00 PM
Senior Member
Jdub's Avatar
Actually yes, it does, depending on your current mileage and known replacement dates for your axles. If you have say over 135K on an original set of axles I would have them replaced. Many will suggest regreasing the existing, and that can work. But I found at 145K, even after rebuilding the old bearings, the best solution was to replace the bearings at a minimum (and for you, replacing that essential boot that keeps the road crud out).
'78 Targa in Minerva Blue
Old 08-21-2014, 02:29 PM
Rodek
The car has the original axles and has about 143K on the clock. I think it would be best to replace both in my case. Now about these bearings you speak of, is this something that requires maintenance in addition to the axles?
Old 08-21-2014, 04:21 PM
Rodek
Can anyone help me understand these bearings mentioned above?
Old 08-22-2014, 06:31 AM
I assume they are referring to the Constant Velocity (CV) joints at each end of the axle. This is what allows the wheel to move up and down and the axle moves with it. Many will just remove the old boots and clean up and then regrease the parts, assuming they are not worn or pitted. I did this about 40,000 miles ago on my Carrera and so far (200,000 miles) they are working fine. At some point I'll probably have to replace them. There are a number of threads on this subject, just do a search on rebuilding cv joints and you'll see what I mean.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 08-22-2014, 06:58 AM
Rodek
Thank you for the education on cv joints. I'll do a search on rebuilding them and see what I come up with.
Old 08-22-2014, 01:26 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by Rodek View Post
Thank you for the education on cv joints...
Just not yet. Once you read the 400+ post of this one you will be ready for a DIY
Reconstructing Constant Velocity (CV) Joints
Who Will Live... Will See
Old 08-22-2014, 03:05 PM
Rodek
Oh my! You're right! Lots of info from the link you posted. I'll get to reading more right away. Thank you!
Old 08-22-2014, 05:23 PM
