Ds1 Ds1 is offline
How The Heck Do I Install These 6 Points Harnesses?
Harness install - yes I've read the instructions, all the mounting points are pretty straightforward except for one, which is very confusing....
The submarine belt.
I understand the sub belt on my Scroth 6 pointers need to be mounted through the center hole of seat, +/-20 degrees to an eye bolt with some sort of reinforced plate welded onto the floor. I have two issues with that:
1. What the heck does that actually look like? I've searched and searched but cant find a 911SC specific photo. I would be interested in exactly how this is done.
2. My drivers seat is adjustable forward and back. How do I work the drivers position into that +/- 20 degree equation?
Thanks!
Old 07-20-2015, 06:53 PM
moneymanager's Avatar
You don't need to weld anything, just drill two holes in the floor a few inches apart (ie on either side of fore-aft centerline) and position as directed. Use big 2-3" washer under bolts. Place the seat so the 20° is right for you in your driving position. Everyone else will have to live with that.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 07-20-2015, 09:07 PM
Bill Verburg's Avatar
The submarine belt.
Thanks!
This is what the pad eyes look like
Mounted
I've seen them knocked off the bottom of the car soooo,
A better way, if allowed, is to use GT3 bars
Bill Verburg
Old 07-21-2015, 04:54 AM
Ds1 Ds1 is offline
Hmm seems simple enough. I have Corbeau sliders, maybe my fab guy can build something like the GT3 setup.
Thanks guys.
Old 07-21-2015, 06:12 AM
