You need to solve the differential equation and understand how each variable affects the stored energy: Voltage (coil) = L (inductance) X d I (change of current) / d T (change of time)
Dave |
You need to take an microcircuits class and figure out what T502, T505, R528 and R518 do in the DME.
Rick 88 Cab |
Rick, the DME has coil charge time (Dwell Time) I know this 100% for sure because I know were the Dwell map is and how it works. I actually tune the Dwell when using non stock coils I also slightly tuned it for the stock coil at lower RPMs since the stock table is a bit shy of fully charging the coil with the stock Map.
But you are also correct that the darlington transistor has over current protection as well but that's used as a fail safe in case the coil shorts out. I scope the coil and alter the Dwell map to watch charge times and saturation. I can easily stop charging the coil far before 8AMPs if I wish, the DME has both things built in, a Dwell Map and over current protection but the Dwell map comes first in calculating when to start charging.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 09-07-2014 at 10:22 AM.. |
At idle is it hitting the current limit? This is the only place I looked at it.
Rick 88 Cab |
Dave |
No, or the coil driver would be over-heated, i.e. Power ~ = 8 amps X 13 volts - 8 amps X 8 amps X coil resistance.
Dave |
For 0 di/dt the power in the darlington would be 12*8 or 96 Watts which it won't do very long. I was under the impression from everything I've read and seen they contro the dwell to just hit the current limit.
Rick 88 Cab |
I actually use a scope and increase dwell time till I saturate the coil then drop back to about 90-95% charge.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
I think the engineers added the over current sensing as a durability feature for the DME just in case the coil shorted out or the drive line was somehow shorted to 12vdc.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 09-07-2014 at 10:59 AM.. |
Dave,
First, my sincere apology. You are correct that your method for testing coil pulse works. I tried it and it works exactly as you say then I thought about it and I see why it works. I just tend to use LED test light for everything since the LED works great even on Speed and Ref sensors. Once again sorry. Quote:
They sure went to a lot of work to do it however. That circuit is a work of art for the 80's. Look at how they limit saturation, the select in test resistor to set the current. And if you ever use it because the timing gets lost it burns itself up.
Rick 88 Cab |
FASTLAP
Update:
Definitively the no-start was caused by the DME. Anyone have a good used DME (1987 911) for sale.
1987 911 3.5L 1987 924S 2005 Audi A6 Quattro 2003 Cooper S |
FASTLAP
Thanks to all, for the help!!
Spiderman
Repair ?
If you're sure the DME is the culprit, why wouldn't you just send it to one of the folks including Pelican who could repair it ? There are several as I remember who can test and re-solder parts or joints on DME's, cruise modules, etc.. Then you know what you're getting.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Agreed - I suggest a bench test and inspection would be on order next. Let me know if you need help.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
FASTLAP
That's the plan! Sending it out to Sal for repair and upgrades.
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
| Tags |
| no spark , no start |
