Cannot identify this part thats leaking-Help (pics)
Good Morning gents,
I have a decent leak that is is on the bottom of my car. After crawling under, I have located it this "connection". Can someone please tell me what this is? Is it part of the oil cooler? I didnt think so since its below it. The leak is coming from where the two parts join. I tried to tighten the two bolts, but it still drips on my heat exchanger. It looks like an oil feed tube. Is there a O-ring that fits there, or a gasket? Would really like to take care of this. Thanks alot guys. Really appreciate it. ![]()
1984 "Chiffon" Targa 1986 951 Wessiech 1986 951 Crystal Green Metallic 1986 951 Garnet Red |
Engine mounted oil cooler. Right at that spot it has a rubber washer seal.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Thanks so much!
Would you be able to show me what the seal looks like? Part number?
Once a friend of Cliff
they, as old as most of them are may have also had a cooler failure. try the 3 new rubber seals, but it might be a good idea while out to have it pressure tested.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Thanks! is it only one seal that fits in the tube? How do they look. I cannot find it in the bentley manual.
Thanks again!
Search our hosts catalog for 'oil cooler seal' they will come up. Round green seals.
And this tech article may help: http://www.pelicanparts.com/techarticles/911_oil_cooler_repl/911_oil_cooler_repl.htm
as mentioned aboive i would pull the cooler and send it off for cleaning and testing, or jest get another kown good one from a supplier . if its a decent leak il bet it has a leak and its not the seal
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I cleaned the cooler, then taped off the location to confirm its coming from seal itself. When I unbolt the two bolts, Does the seal just sit in there? I ordered the seals. Im just curious how it actually " seals" .
If the cooler ever need to be replaced, is it a difficult job? Really appreciate the help gents.
