Cannot identify this part thats leaking-Help (pics)
Good Morning gents,
I have a decent leak that is is on the bottom of my car. After crawling under, I have located it this "connection". Can someone please tell me what this is? Is it part of the oil cooler? I didnt think so since its below it. The leak is coming from where the two parts join. I tried to tighten the two bolts, but it still drips on my heat exchanger. It looks like an oil feed tube. Is there a O-ring that fits there, or a gasket? Would really like to take care of this. Thanks alot guys. Really appreciate it. ![]()
1984 "Chiffon" Targa 1986 951 Wessiech 1986 951 Crystal Green Metallic 1986 951 Garnet Red |
Engine mounted oil cooler. Right at that spot it has a rubber washer seal.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Thanks so much!
Would you be able to show me what the seal looks like? Part number?
More Likeable IRL
they, as old as most of them are may have also had a cooler failure. try the 3 new rubber seals, but it might be a good idea while out to have it pressure tested.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Thanks! is it only one seal that fits in the tube? How do they look. I cannot find it in the bentley manual.
Thanks again!
Search our hosts catalog for 'oil cooler seal' they will come up. Round green seals.
And this tech article may help: http://www.pelicanparts.com/techarticles/911_oil_cooler_repl/911_oil_cooler_repl.htm
as mentioned aboive i would pull the cooler and send it off for cleaning and testing, or jest get another kown good one from a supplier . if its a decent leak il bet it has a leak and its not the seal
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I cleaned the cooler, then taped off the location to confirm its coming from seal itself. When I unbolt the two bolts, Does the seal just sit in there? I ordered the seals. Im just curious how it actually " seals" .
If the cooler ever need to be replaced, is it a difficult job? Really appreciate the help gents.
