Quick 88 Carrera Fuse #3 question
Ok i'm replacing my fuse panel in my 1988 Carrera with an ATO fuse panel. One thing I cant figure out is fuse #3 (third from left) is for convertible top, headlight cleaner, and an additional cleaning fluid pump relay (as per my wiring diagram). I don't have a convertible or headlight cleaners and I'm assuming the additional fluid relay is for the headlight cleaner system. Here is my question: On my fuse panel I still have a wire (Red and White) coming off the #3 fuse. Does it power anything that I'm not seeing or is it just part of the harness that automatically installed at the factory if you have the options or not? Can I just skip reinstalling the wire and use the fuse spot for something else?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse question.
![]() Welding point X is for the convertible top. I use the output of fuse #3 for the front A/C condenser blower motor. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
So it looks like i'm going to delete fuse #3. I never would have figured out what welding point x was. Thanks 86 you've come through again for me
Fuse.
It's a no-brainer. Here are the pics: Good luck, Gerry pm me as needed. ![]() ![]() ![]()
Hey Gerry thanks for the advice but my A/C is long gone. Im going to use the extra fuse block for power to one of the headlight relays.
Northern Motorhead
Pay close attention to the bridged fuses,i did my ATO conversion last Winter and got stumped when it came to connecting those circuits.You will need to fabricate a few jumpers !
Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Thanks wildcat077, I'm on it! I have spent many hours going over schematics just to make sure I dont screw anything up. The only one I will not know until I remove the old fuse panel is the other fuse 3#, the fuel pump. My schematics say there is a jumper to it but it must be on the backside of the panel. I guess I will see when I take it apart.
Northern Motorhead
For reference,this is what my installation came out like with the headlamp relays ...
Cheers Phil
Beautiful! Very clean. Is that one of Fred's panels? Did you screw it to the old fuse panel bracket or did you use double stick tape to hold it on?
Northern Motorhead
Yup,one of Fred's panels ... it fit perfectly using the original mounting points.Take note of the jumpers ...
You will need to be creative and fabricate a few.Make sure you have plenty of female terminals where you can splice two and three wires together and shrink wrap everything afterwards ! Cheers Phil
88 Carrera, Guards Red
hey 86 911 targa, nice job with the pictures of the back of the fuse panel at the ac condenser relay. I agree, why would someone not switch the condenser fan to unused #3? even if they have a headlight squirter the #3 fuse location distributes the ac load much better. Its actually very easy after you get past the fear of taking the fuse panel off the fender. as for me changing to fred cooks ato panel was the perfect time to do it.
Member 911 Anonymous
Sorry for the Hi-Jack OP,
Dr Gerry, which gauge of wire should one use, can't tell from pics, it looks like 12??? ![]()
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Nice job!
Always nice to see the finished product! You did a very nice job on the swap out!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
