toddu's Avatar
Oil line - tank to thermo
I had my tank refurbished, and also installed a new line from the tank to the thermo. I *thought* I had the fitting as tight as it would go, but I was still getting a small drip develop.
Changing my oil today, and I've removed the line at the tank. All looks ok, no burs, etc. on either side (line or tank). What else should I check? Hate to put fresh oil in just to have it leak again (and have to remove the line again).
Note - when I first hooked everything up, I had not removed the clamp securing the lines that run to the thermostat, and there wasn't a lot of slack for the line to the tank. I suppose that might have impeded a snug fit, or the "socket" not fitting in the tank outlet squarely.
Todd
'81 SC
Old 09-11-2014, 11:10 AM
Try tightening when the the engine/oil is hot.
- Mike
Old 09-11-2014, 11:34 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, I remember using a cheater bar to torque those suckers
'85 Carrera Targa
PCA/POC
Old 09-11-2014, 12:44 PM
toddu's Avatar
So, you're both suggesting that it merely wasn't tight enough (to reiterate, it's the connection at the tank)? I'll try it again I suppose. Wish there was a way to test prior to filling oil.
Todd
'81 SC
Old 09-11-2014, 01:22 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Those oil line connections are spherical compression fittings so they shouldn't take a ton of tightening. I would say it's a good idea to loosen the clamps on the line so you can get the spherical male end to "square-up" with the receiving female end on the tank as much as possible.
Also, not trying to be a jagbag, that line going to the tank isn't an outlet. It's coming from the return side of the t-stat so its actually an inlet. The oil goes into the tank and up a tube to feed the oil filter housing.
Kevin L
'86 Carrera "Larry"
Old 09-11-2014, 02:44 PM
Registrierte Benutzer
SC Eddie's Avatar
Thanks for the great diagram Kevin!
"It all comes down to never giving up…" Ferry Porsche
_______________________________________________
1980 911SC coupe
1997 Lincoln mkiii
Old 09-13-2014, 09:04 AM
The return Line to the tank that's threaded goes to the oil filter through tubing inside so there isn't much oil to loose.
Bruce
Old 09-13-2014, 10:21 AM
toddu's Avatar
Yeah, it's just an annoying dribble. Especially since the engine has been redone and no longer leaks.
Put the line back on. Made sure the male fitting was nice and "square" in the female fitting. Hopefully dribble is gone
Todd
'81 SC
Old 09-13-2014, 01:01 PM
MConn's Avatar
Originally Posted by toddu View Post
...Wish there was a way to test prior to filling oil.
Todd
If you haven't already filled the tank with oil, it seems like you could put 3PSI of air at the oil tank filler neck by taping a freezer bag on the opening, and spray soapy water on the leaking fitting and look for bubbles. I haven't tried this myself.
Mike
The more I learn, the less I know.
Old 09-13-2014, 05:22 PM
the line at my carrera cooler was leaking like crazy when i first put it on. i ended up making the fitting just snug rather than tight and it stopped leaking. so maybe try that
Old 09-13-2014, 07:02 PM
Those fittings require the mating faces to be clean so that they seal tight. Verify they are clean and that there are no radial scratches. You may have to buff with a little Scotchbrite to clean them up (careful not to get that stuff into the oil line).
Old 09-13-2014, 08:03 PM
BoxsterGT's Avatar
Porsche Crest
If it comes to a "last resort", there are soft copper rings available...........
...to help seal the mating point. They act like a crush washer similar to what's used with fuel systems & drain plugs. I have had success with these previously.
Even a soft Aluminum ring might work as a substitute.
Len
Old 09-19-2014, 09:48 AM
toddu's Avatar
Good to know! I've used something similar on a pesky AN fitting. I'm filling the tank up this weekend, fingers crossed.
Todd
'81 SC
Old 09-19-2014, 10:33 AM
hi were, would I buy. the copper o rings. thank you. carl
Old 09-23-2014, 02:59 PM
toddu's Avatar
You can get them at Pegasus, Jegs, etc.
Btw, reinstalled my line this weekend and no leaks !!!
Todd
'81 SC
Old 09-23-2014, 03:12 PM
thanks todd ,is there a webb site . carl,
Old 09-23-2014, 03:47 PM
Guardsred911's Avatar
I have had similiar issues at the same joints.... what fixed it for me was backing the nuts off, putting copper anti seize on the threads so it wouldn't gall and would have less resistance when tightening. Then I made sure the male end of the fitting was firmly square and pushed in as I was tightening it down.... after doing that, no leaks.....
J
911 SC - 1980
911 S - 1977
Old 09-23-2014, 03:55 PM
