Speed Metal Army General
Tach not firing up right away?
Sometimes my tach doesn't work off the hop! If I razz the motor a bit it comes to life and stays on line. Once its working it does so flawlessly. I did search for this problem(Pre-emptive defence here) but found a ****ton of stuff about non-working tachs. Mine works, its just late for work by a a few seconds! Advice please.
Old 10-08-2014, 08:51 PM
Mine is the same. Subscribed.
Old 10-08-2014, 09:01 PM
Mine does that when my battery starts to weaken, then I charge the battery and the symptoms go away. Might just be coincidental.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-08-2014, 10:02 PM
On my 73S it appears that the glass has warped because after sitting for more that one week, upon starting, the tack will not move. If I tap on the glass the needle will move freely.
Old 10-09-2014, 01:51 AM
KBOUSTANI's Avatar
Mine do that when the outside temperature is over 90 degrees.
But once I drive my car for 5 minutes it comes back to life.
My car stays in the garage and this never happens until it's park outside for more then two hours.
76 carrera 3.0 SSI W/M&K 1RARE76/]89 carrera 4 (964)SOLD
87 targa 3.2,fabspeed cat bypass,sw chip,m&k exhaust(sold)94 carrera 2 cabriolet(sold)00 carrera 996(sold)
95 993,red,meanest looking one(sold)
83 911 sc targa,my first porsche(sold)
Old 10-09-2014, 06:51 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Gentlemen, have you all check the ground behind the tach to insure they clean and tight? This is just not normal. my 2 cents. I know it is a PITA to remove the tach but I would check the contacts especially the ground.
'85 Carrera Targa
PCA/POC
Old 10-09-2014, 07:14 AM
Yep, easy peasy, I have the quick release steering wheel,the tach pops right out in seconds, connection does not seem to be the issue for me.
Old 10-09-2014, 10:43 AM
theiceman's Avatar
i had this .. and i had a wild swing also .. like there was no damping action .
i bought a tach core and swapped them out while i got mine rebuilt. all worked great so i never got mine rebuilt. I think you will find your problem is the tach.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-09-2014, 12:45 PM
