What is it- HELP?
I found this on the A/C evaporator blower motor- stuck by the magnetic field. Anyone know where it's from? I have an 85 911 Carrera.
Thanks. ![]()
Fleabit peanut monkey
It's one of the clips from hell that hold the top of the evap cover/fan housing to the bottom half of the housing.
1981 911SC Targa |
clip
I don't think so. There are 4 clips that hold the top and bottom housing together and I have those. This clip doesn't fit the plastic nubs on the housings.
It may be a weight to balance the squirrel cage.
Is it the right size to clip on to one of the vanes?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
clip
The squirrel cage weights are much smaller.
That's the clip to hold a Bowden cable to the airvent assembly.
You need to post this in this thread, then grab some pop corn.
![]() http://forums.pelicanparts.com/porsche-911-technical-forum/829966-my-ac-burns-me-up-help-part-2-a.html
72 911 Although it is done at the moment, it will never be finished. |
That clip holds the wires to the blower motor
clip
That's it! Thanks much.
