Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
help installing camshafts
Im installing my camshafts using waynes book...its pretty clear in the book which cam goes on the left and which cam goes on the right. My problem is that I dont know which side of the engine is left.
the cams are inserted from the back of the car, so is the left bank cylinders 1,2,3?
thanks!!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 09-30-2014, 06:31 PM
Kemo,
Yes you are correct.1,2,3 is left
Old 09-30-2014, 07:25 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by Steve_R View Post
Kemo,
+1. Left right is from rear of car or sitting in driver's seat looking forward.
In the PET diagram you can see the chain layout along with the cams. Part numbers, etc.
I remember in Bruce Anderson's book he mentions the lobe orientation on the right cam make the lobes look like Rabbit ears. R for rabbit.
Here's the PET link.
http://www.porsche.com/all/media/pdf/originalparts/en/E_911_83_KATALOG.pdf
1981 911SC Targa
Old 10-01-2014, 11:05 AM
Odd number at the end of the casting number is left, even is right. Like "103" and "104". (Those are just examples and have no relation to the real numbers!)
The Cap'n
Old 10-01-2014, 11:46 AM
Peter Zimmermann's Avatar
Don't forget/skip setting parallel alignment of the chain sprockets, and put those cam/chain sprockets on correctly. Also, you need the proper chain rails/guides; five of one dimension and one different, and make sure those guides face the right way.
Keep the Shiny Side UP!
Pete Z.
Old 10-01-2014, 03:25 PM
Gordo2's Avatar
Engine Rebuild Book
The book describes left/right in one of the early intro chapters - I dog eared it because I kept confirming as I rebuilt my motor - after a while, I finally just wrote L and R on the case halves with a sharpie...
I like to simplify things to the max extent possible...
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 10-01-2014, 05:39 PM
Black and Blue
Kemo's Avatar
thanks for the input... i guess a rule of thumb would be "as you are sitting in the driver's seat"
left and right. I might still use that sharpie!!!
Kemo
Old 10-03-2014, 09:31 AM
Unless, of course, you're in Japan, the UK, Hong Kong, Australia, or many other current or former parts of the British Empire ...
Old 10-03-2014, 09:54 AM
Errr. Drivers in those countries still face forward when driving, yes? If so, left and right still apply while "driver's side" doesn't. But then again, cam installation uses "left" and "right" references.
Sherwood
Old 10-05-2014, 11:17 AM
