'73 911 T Targa
Question about Klein 21 Spark Plug tool hex drive size
I have a Klein 21 spark plug wrench that I really like for starting spark plugs. I'd really like to do the final tightening with the tool too, but I don't have a tool that fits the hex drive. While looking for an allen wrench or allen socket, I discovered that 10mm is a little small (sloppy fit) and that 11mm won't go in. Is there a special sized hex tool specifically designed to fit the Klein 21 tool?
Old 10-01-2014, 04:15 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
A Torx #50 fits almost perfectly and engages 50% of the splines. I don't know if Klein makes a bit or socket to drive the tool other than the L shaped wrench that came in the factory tool kit.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 10-01-2014, 05:57 PM
Upon further research, a triple square bit would be a perfect fit, as it has 12 facets to engage all of the factory tool's spline recesses. I would buy a set rather than just one as I don't know what size bit is required (maybe 8 or 12mm)
Also, many newer models (996 and forward use this fastener with this kind of head) at least in one place I can recall. (door striker plate)
VIM Tools XZN100 3/8" Drive Metric Triple Square Bit 8-Pc Socket Set VIMXZN100
Old 10-01-2014, 06:19 PM
'73 911 T Targa
Hmmmmmm. Did later tools have splines? Mine is a hex drive. But - It's not 10mm; it's bigger than that, but not quite 11mm.
Old 10-02-2014, 05:10 AM
Hmm, must be different form my tool out of the 964.
Here is what mine looks like:
Old 10-02-2014, 02:56 PM
