'73 911 T Targa
Is there a special wrench for the distributor nut?
I know this probably sounds dumb, but I'm wondering if there's a special tool or a certain wrench to tighten the nut that holds the distributor in position when adjusting timing. On mine (as I'm sure many are), the vacuum advance prevents me from getting a socket in there, and a box or open end wrench can only move a few degrees before hitting something. Is there a special wrench?
Old 09-30-2014, 08:48 AM
faverymi's Avatar
I use 13mm crowfoot with a socket extension and a ratchet.
Hope it helps
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 09-30-2014, 08:54 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1
'85 Carrera Targa
PCA/POC
Old 09-30-2014, 09:02 AM
Oh Haha's Avatar
+2
Pacific Blue
Wayne
Old 09-30-2014, 10:32 AM
I bought a 13mm open end from Sears, heated it and bent it to the angle needed. I use that in combination with the crow's.
Old 09-30-2014, 10:44 AM
'73 911 T Targa
I found this custom made tool on Ebay!
13mm Crow Foot Extended Flare Nut Tubing Line Wrench 3 8 Drive 6 Point | eBay
Old 09-30-2014, 11:37 AM
Enthusiast
jrolstin's Avatar
stubby 13mm works fine, but a little awkward...
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 09-30-2014, 12:11 PM
Josh D's Avatar
I use a distributor wrench that I bought at the local auto parts store. It's bent around the distributor and utilizes a 3/8 drive. Looks just like this one:
http://www.summitracing.com/parts/oes-25289?seid=srese1&gclid=CKX6-pfaicECFRJk7Aod2xsA9g
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 09-30-2014, 12:44 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
a small wiggle socet works well. 13 MM socket that allows an angle (like a CV)...Sears. Comes in handy for other things like heat exchanger nuts.
Chris
73 911 E
Old 09-30-2014, 01:38 PM
Bill Verburg's Avatar
I've got a bunch of funky bent end wrenches, 13mm crows foot for the distributor
Bill Verburg
Old 09-30-2014, 02:09 PM
wheres all youre tools Bill? If i had that little in each drawer id need about 25 tool boxes lol yeah i just rummage around in there till I find something thatll work. its not like you need to move it every day
Old 09-30-2014, 02:19 PM
I'm organized and yes, there tools in a dozen chests, I try to keep them sorted by function
For instance some(but not all) of the torque wrenches
Bill Verburg
Old 09-30-2014, 02:26 PM
nice. maybe ill get some shots of my box and see how Dis functional it is. I know where everything is but people seem to put stuff back in just wherever it fits.
Old 09-30-2014, 03:47 PM
ME TOO....I would not have enough garage space if I had tool empty tool boxes like that.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 09-30-2014, 10:01 PM
Most major tool manufacturers (Snap On, Vim, Proto, etc.) make distributor wrenches, SAE and Metric. Peruse eBay for a wide variety of shapes. Can also use to access heat exchanger hex nuts.
Sherwood
Old 10-05-2014, 12:20 PM
Fwiw, I use a regular 13mm open ended wrench. 1/8 turn, flip, 1/8 turn, repeat a couple more times and finish with fingers.
Old 10-05-2014, 09:47 PM
