beancounter
jwasbury's Avatar
915 trans - stiff shifting after hamfisted driver
Last day of the track season I made the mistake of letting a guy take a few laps driving my 911SC based racecar without first observing him driving his own car. This guy was an absolute spaz with the shifter, slamming the hell out of it, and in about 2 laps it seems something got screwed up. I yelled at him to take it easy, but the damage was already done.
Moving the shift lever either front to back, or side to side became very stiff, and shifts were not very positive feeling so it became very easy to miss them or hit a wrong gear. Initially I thought it was damage to the Hargett shifter, but upon removing the shifter I found that mechanism was smooth and supple. The binding/stiffness is apparently the shift rod itself, so the problem internal to the transmission.
I've got the box out of the car and my current plan is to take it to Gary Fairbanks, have him look it over and fix whatever is needed and perhaps some other 'while you're in there" stuff. I've been inside 911 engines several times so I am pretty comfortable how they work, but the gearbox is a thing of mystery to me. Any ideas what is likely to have been damaged by my hamfisted friend?
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 12-08-2014, 02:09 PM
Wer bremst verliert
JohnJL's Avatar
Your friendship.
Sorry, I am in the same boat as you...good working k owledge of the sparky bits but the gears are a mystery to me...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 12-08-2014, 02:12 PM
beancounter
jwasbury's Avatar
Originally Posted by JohnJL View Post
Your friendship.
funny
I can only fault the guy so much. He'd never driven a vintage 911 before (currently tracks a 997 street car) and I encouraged/pushed him to give it a try. My excitement to share the joy of the aircooled 911 got ahead of me.
Jacob
Old 12-08-2014, 02:17 PM
Yup, I learned my lesson a long time ago. If anyone asks if they can drive my 3.2 I just say "No".
Old 12-08-2014, 02:36 PM
I am surprised that he could not sense that he was forcing things!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 12-08-2014, 02:59 PM
Almost Banned Once
sc_rufctr's Avatar
Ask your mechanic to check the shift fork inside the trans. A loose or misaligned one can cause these symptoms.
This was how mine looked when I first opened up the trans on my 78.
I also had other issues but as you can see one of the studs was broken and the other two were loose also. I've always driven and shifted my car sympathetically.
Apparently this is a common problem. Your "friends" ham fisted efforts could have dislodged yours.
- Peter
Old 12-08-2014, 03:25 PM
gearhead
I was thinking the same thing. Either it came loose or a finger broke. Nice thing is you can check and repair it with gearbox in car. Just drain the oil first.
Old 12-08-2014, 04:11 PM
OsoMoore's Avatar
I encourage you to take a look at this yourself. The transmission seems like a crazy thing, but inside it isn't that complex. The same mechanism is just repeated 3 times, once for each gear pair.
Definitely start by taking off the inspection port, hopefully it's just the fork. If not, there are lots of great threads here about how to dissasemble and repair a 915. I did so with my own a few months ago. I haven't taken the engine apart - it was my first time dropping it. So if you can do significant engine work, a 915 teardown is definitely within your skill range.
Can't Shift Into First
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 12-08-2014, 04:23 PM
Walt Fricke's Avatar
Like Oso, I was fearful of transmissions for more years than their design called for. They aren't that complicated, you can make up or fake most of the special tools which are helpful, you can have a shop do things which really are tricky (like setting up a replacement ring and pinion), and when it comes to replacing the dog rings on the gears you can give those to a shop also.
Checking the fork shown in the picture is dead easy. About the only trick is to remove the transmission oil filler plug first. Why? Because if you drain the oil, and then can't get the filler loose, you are in a bit of a pickle.
If the fork is tight, you might look at how the shift forks attached to the two sliding shafts align. One of these is built into its rod, but the other is clamped on. The "finger" parts which engage the shift sleeves and move them are also clamped onto their rods. If any of these clamped parts move on their rods you have troubles. Unfortunately, I don't think it is possible to realign any of these without disassembling the transmission pretty significantly.
By jamming shifts it is possible to bend the clamped on slot part on one rod. You will see how the rounded end of the dongle which is attached to the shift rod itself rotates up and down to the three gear engagement planes, and lines up with one slot, then the next slot, and for 5th/reverse, is out in thin air outside of both of these slots (because shifting for these gears takes place elsewhere). You can see that if the shift rod is rotated so that the dongle end is placed right between the two slot pieces, and then shoved forward or back, it can try to spread the two apart. One isn't going to budge, but the other one can be bent. I am certain of this because I did just that trying to get into 1st when angry. As it turns out, what is bent can be bent back, and externally to boot. Not likely this is what happened to your 915, but if it is you will know how to spot it and how to fix it.
If it turns out that clamped pieces were moved, I would have the transmission shop you involve, if you do, knurl the shift rods in the area where the pieces clamp. Won't cost much extra, and will pretty much preclude it happening again. If you do the work yourself (there is a super tutorial you can find here on Pelican by a guy who has a lifetime of professional work on these transmissions), you could take the shafts, with the areas you want knurled marked, to any machine shop to have that done.
997s are so easy to shift I am a bit surprised that would lead to ham handed shifting. Longer throws, sure. A bit more pressure needed, sure. Less certainty what gear you were about to engage, that too. But jamming it?
Old 12-08-2014, 04:55 PM
you might want to look into the WEVO internal shifter gate. I have one in my 915 and love it.
03 Boxster
Old 12-09-2014, 06:22 AM
1984-911 M491
Trog's Avatar
Originally Posted by dicklague View Post
you might want to look into the wevo internal shifter gate. I have one in my 915 and love it.
+1
1984-911 TLC......SOLD
Old 12-09-2014, 06:42 AM
On a more basic level, I'd take a look at the internals. A gearbox in good condition should shift fine. Add the Wevo item afterwards.
Sherwood
Old 12-09-2014, 09:12 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Check out the 915 wiki by Peter Zimmerman. It's a very good tutorial on 915 teardown, inspection & rebuild.
List All Pages - Porsche Wiki
Kevin L
'86 Carrera "Larry"
Old 12-09-2014, 09:18 AM
mussberger's Avatar
You're lucky he didn't buzz the motor as well. I talked to Fairbanks once. Bavaro has done mine since then.
1981 911SC Black metallic, no sunroof. Sold(damnit)2005 987Guards Red, Stuttgart build. Sold1978 911SC Bahama Blue, M491 look E class PCA race car.Sold with help from Pelican. Thanks! 2005 997 Black. Sold1988 930 Grand Prix White. Keeper. 2008 957 Basalt Black, Pneumatic suspension and PDCC.
Old 12-09-2014, 12:44 PM
Sherwood
++++that is what I meant. Looking at the parts in the photo reminded me of the WEVO.
I have had the internal gate shift if my 915 for a few years and maybe 10K miles and love it. Makes things really positive.
03 Boxster
Old 12-10-2014, 07:03 AM
beancounter
jwasbury's Avatar
Bumping this back up. I finally have had the chance to peek inside my 915. The fork on the cover plate appears to be intact, so my problem isn't there.
The shift selector rod is noticeably stiff when trying to rotate between 1-2, 3-4 and 5-R planes in the neutral position.
I removed the nose cover and the shift selector rod is much easier to move around with the cover off. As an experiment, I bolted the nose cover back on and observed that the shift selector rod was stiff again. Then I loosened the nose cover bolts so it had some wiggle room, tapped the perimeter slightly and allowed the cover to open up just a bit from the gear case. That little extra room makes the shift selector rod much easier to rotate. Wondering if this is an indication that the selector rod is bent somewhere? I can't see anything obviously bent or out of place. All gears can be selected, just a huge amount of effort to move the shift selector rod around.
I am all ears to ideas to what else I should look at.
Thanks...
Jacob
Old 04-28-2015, 05:10 AM
Eva
911SauCy's Avatar
You're quite graceful in taking this as you are.
I understand the guy wasn't used to shifting a 915 but no matter my relationship to someone, I'd never take their car out and just smash it around...if I did and the result was similar, I'd expect to receive the repair bill.
Good luck as I couldn't tell you my arse from my elbow which bits that should or shouldn't be inspected.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 04-28-2015, 05:28 AM
gearhead
That sure does sound like a bent shift rod.
Old 04-28-2015, 06:57 AM
beancounter
jwasbury's Avatar
^this was my novice diagnosis based on the test performed. I'm struggling with how that part could be bent by beating the hell out of the shifter?
One other question: when you rotate the shift selector rod to access the 5-R plane, is there supposed to be a noticeable detent that wants to push the rod back to the 3-4 plane? I thought there was some spring loaded "feedback" when going for the 5-R plane, but perhaps that's built into the shifter and not the gearbox itself.
Jacob
Old 04-28-2015, 07:14 AM
beancounter
jwasbury's Avatar
I will see the perp again, and when I do I am going to mention the fact that I believe he damaged my gearbox. My purpose is not to shake him down for money, but to educate him that if he persists with the hamfisted/spaz shifting technique, his track car hobby is going to be more expensive than it needs to be.
I'm not too fussed about my car because I was planning to drop the engine and do some upgrades anyway. I wasn't planning on opening the gearbox but its not hard to do at this point anyway. The cost of fixing this is a squirt of piss in the grand scheme of my race/track hobby. I chalk it up to a learning experience for me: from this point forward, I will observe a person driving their own car from the right seat before I invite them to test drive mine.
Jacob
Old 04-28-2015, 07:20 AM
