47silver's Avatar
removing a 72 dash and do not understand
what is connected inside the plastic, cover that i found in each corner of the dash. do you pull up on the dash at these locations? i am stopped at this point.
the part is as shown on picture, what goes inside it?
1975 911S Targa
Silver Anniversary Edition
Old 10-14-2014, 06:48 PM
Not sure I understand the question but those are plastic cups that clips go into for most german cars anyway. Door panel clips go into those, I'm guessing dash top clips too (but the only dash I pulled was a long time ago).. I imagine they make for a tighter and quieter fit (like an anchor with a screw in it)
Old 10-14-2014, 10:15 PM
ROW '78 911 Targa
timmy2's Avatar
Here you go.
Receivers for the clips attached to the bottom of the dash.
My '78 takes 7 of them,
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-14-2014, 10:26 PM
Did you try pulling up after you got all the nuts off of the studs sticking through the dash into the trunk department? Those are pretty hard to get to.
Marv Evans
'69 911E
Old 10-14-2014, 10:47 PM
47silver's Avatar
dash
I removed the heater system and the windsheild wipers and the gauges. I double checked and have all of the fasteners off of the dash, the only 2 things that seem to be holding it are whatever are inside these plastic things that are at the corners of the dash. i do not know if they pull straight up or is there a clip that needs depressed..
a picture of what is inside these would be great.
1975 911S Targa
Old 10-15-2014, 05:11 AM
kodioneill's Avatar
Post #3 shows whats inside the receiver.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-15-2014, 05:26 AM
Science is NOT optional
rbogh901's Avatar
I'm assuming that your windshield is out?
PCA member since 1993
Old 10-15-2014, 05:48 PM
47silver's Avatar
thanks for the picture
the wiindsheild is out the dash is in great shape so i did not want to pull to hard
can i just cut there offf and get new ones?
1975 911S Targa
Old 10-15-2014, 06:41 PM
chadco's Avatar
There are approx 6 of these across the top of the dash. One one each end as you stated and one on each side of the rectangular spaces where the defrost vents snap into the dash. You don't have to cut anything, just lift up with moderate pressure at each point described and it will just pop up. Make sure you have all the nuts off first before pulling it up. I just took my Dash out last week with no problem. Mine is a 79 but they should be very close to the same. I can send pics tomorrow if needed. Good luck just take your time.
Old 10-15-2014, 07:46 PM
I found these pictures in this forum.
Old 10-16-2014, 11:28 AM
47silver's Avatar
thanks
mine had bolts with nuts on those areas... the only plastic tabs i found are on the corners...the car was painted in the past so perhaps they used bolts with nuts in some fashion.. i will post pictures when i finally get a moment to remove it.
1975 911S Targa
Old 10-16-2014, 11:31 AM
