New SSIs and O2 Sensor
About to pull the trigger on a new set (91.911.SSI thin flange + 2/1 Dansk w/ 60mm tip) and see that they no longer come with the O2 bung. Now my car's old exhaust system consisted of factory HEs with crossover pipe jury-rigged into a factory cat. I believe the original Euro pre-muffler was cut and replaced with a section of pipe that included an O2 bung. Ironically, the sensor was present but apparently never connected. Car ran this way for years and years, and my P shop was aware of it. Can I run the car with SSis and no O2 sensor, or do I have to modify a nice new and expensive set of SSIs to add a bung?
Thanks! |
Vintage Owner
It should run, but not as efficiently as with the O2 sensor connected. I'd wonder if it wouldn't be a good idea to have a bung welded onto the SSI exchangers, just find a good welder that can weld stainless steel properly.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Thanks... What exactly do you mean by efficient? Performance, fuel economy, etc?
I welded a bung to the inlet pipe on my muffler - I don't think you have to put in on SSI.
Chris '75 911s 3.2 - Ice Green Metallic ‘87 951, '05 987 S '21 Jeep Gladiator ‘18 Tesla ModelX 100D, ‘20 Model 3 |
After reading through quite a few threads on this topic I've found that ROW cars (like mine) never had an O2 sensor, so the logical conclusion seems to be that I don't need one for the car to be set up properly and run as intended. Then again, there seem to be plenty of contrary points of view?
Fleabit peanut monkey
Not really. You don't have one and you don't need one. If you get one, the car will not recognize it.
Do look in the driver's side engine bay near the fuel filter for an O2 connector. Looks something like the one in this pic. The harness where it mounts on the frame appears to be missing/broken? Also, I don't know if imported ROW cars had to have the Lambda system installed. If so, look for any old floating connector. Maybe the easiest way is to look under the passenger seat for a Lambda control box. If you ain't got one...............
1981 911SC Targa Last edited by Bob Kontak; 10-21-2014 at 01:31 PM.. |
oops - Forgot pic. By the "U" in the fuel line.
1981 911SC Targa |
Vintage Owner
I was assuming you have a Carrera with Motronic. The thin flanged SSIs should have clued me that it's not one. In that case, the O2 sensor won't be necessary.
I thought all SCs need thick flange SSIs?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Reiver
Not the ROW's, thin flange.
Later year euro's large intake runners, different fuel head on the CIS, dif dizzy and curve, cr 9.8-1, no o2 sensor or corresponding box under passenger seat...204 hp with the crappy 2 into 1 crossover exhaust....with the SSI's and Dansk about what ....215-220 as a guess.
De Oppresso Liber Strength and Honor 5th Legion |
LenS, the O2 sensor is used by an Engine Control Unit to fine tune the amount of fuel being injected into the engine. If you know a little about controls, it might give you a better idea. O2 sensor basically tells the ECU about the AFR, the ECU then fine-tunes the amount of fuel being injected in order to bring the AFR to 14.7 or 15, as suggested by the configuration. If you don’t have an O2 sensor connected, it won’t be big deal while driving within a city but for a long drive, an O2 sensor can save a lot of fuel since you’ll be driving at a constant speed and an O2 sensor removes the steady state error to give the engine exact amount of fuel required.
assembly board Last edited by anders88; 10-31-2014 at 11:06 AM.. |
