Hi
Targa Me's Avatar
CHT Sensor Question
Hello Everyone,
Does the CHT sensor relay data to the ECU for emission purposes?
Thanks in advance.
Larry
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 10-24-2014, 07:14 AM
steely's Avatar
Primarily, I think the O2 sensor is what is used for emission purposes, but the CHT does play a role.
Its info is fed to the DME and, among other sensor info, it's used timing / ignition mapping and idle control. There is some info under Engine Management in Bentley's shop manual.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-24-2014, 08:04 AM
scarceller's Avatar
I assume you are talking about the 3.2L?
The CHT sensor is a critical component to calculating fuel for the given amount of air measured by the AFM. So in a sense it certainly is emissions related because if it's out of spec and say it reads lower temp than the engine really is it will result in rich mixtures that will fail emissions. For example if you unplug the sensor on a fully warm engine it tricks the DME into thinking the Engine temp is stone cold and the fuel increases dramatically and the engine starts to idle hunt and usually results in stalling.
Bottom line is that the CHT sensor must be within spec for fueling the motor properly.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 10-24-2014, 08:22 AM
Hi
Targa Me's Avatar
Thanks Dan.
That reminds me, I think I have a Bosch Motronics manual stashed somewheres.
Old 10-24-2014, 08:23 AM
steely's Avatar
You're welcome - Sal knows much more than I do on the subject, and the Motronics book is of course a better ref than the Bentley.
Dan
Venetian Blue
Old 10-24-2014, 08:56 AM
fwiw, the older CHTs were of a single wire variety that all seem to fail after a while, the newer (replacement) version uses two wires and appears to be more reliable (my '86 had a single wire that failed in the mid '90s -- the replacement 2 wire is still running fine)
Old 10-24-2014, 10:39 AM
